Old 08-31-2008, 08:25 AM   #1
Lariat's Avatar
Lariat will become famous soon enoughLariat will become famous soon enough
Question Tranny in a Can vs. Radiator Stop Leak
It seems there is alot of negative feedback from previous posts about Stop Leak additives for radiators. How does anybody feel about the additives you put in your transmission for leaks and slipping, etc?
Lariat is offline   Reply With Quote
Old 08-31-2008, 10:00 AM   #2
junior3382's Avatar
I am not sure what else you have read, I never looked into it myself, however, I can understand it. I have used stop leak myself for a radiator once and it worked wonders for me. I would not expect it to be a permenant fix, but it got me through. However, for a tranny.... I guess it would depend on where it was leaking. If an automatic is leaking around the filter, the replacement filter kit comes with a new gasket and is usually not that expensive. Seems like a waste to add an additive like that. And for something like that with moving parts and severe reliability needs, I wouldn't use it personally. If the tranny is leaking somewhere else, like a crak in the houseing or something, I would not trust it either. You do not want the tranny to lock up on you while you are driving. The radiator stop leak could get you through and help keep the engine cool until you can get a new one.... if the tranny is leaking, especially if it is bad, I would not trust the product myself.
Old 08-31-2008, 10:02 AM   #3
Lariat's Avatar
How about for transmission slipping?
Every second is a second chance. Live it up!
Old 08-31-2008, 10:04 AM   #4
junior3382's Avatar
using a higher grade, or stronger synthetic for tranny oil might help slipping. There is an additive I have heard of that would also help, but if the tranny is slipping bad, then it may not help. If this is a manual it would be an easy fix for odds are it is the clutch, but for an automatic..... it may be time for a rebuild. Is this an actual issue, or just curious questions?
Old 08-31-2008, 10:12 AM   #5
Lariat's Avatar
It is an issue. But i am waiting for my scan tool to arrive on Tuesday to verify possibly other things. Could a vehicles computer cause the transmiision to fail (not go into the next gear, gauge says 100 mph but going 30 mph)? I feel I have to rule everything out.
Old 08-31-2008, 10:24 AM   #6
junior3382's Avatar
yes... if the tranny is electronically controled then yeah, the ECU could affect the performance. If your tac and speedometer is not reading accurate then no the tranny would not perform accurate... and I would not even drive it until you repair it either...IMO
Old 09-12-2008, 10:48 PM   #7
thomasnchy is on a distinguished road
There is no mechanic-in-a-can.
A slipping transmission or a leaky radiator can't be "fixed" by pouring a liquid in. It can be prolonged, or get ya home but thats about it.
An electronic controlled transmission really is as simple as any other tranny. There are some that have solenoids to switch pressure to different clutch packs that may "hang up" or get stuck, other than that, if its slipping then you need a rebuild.
If your tach and speedo are going hay-wire the I'd blame something electronic.... depending on what you have.
Line pressure and TPS are really the only thing that a transmision (electronic or not) need.
thomasnchy is offline   Reply With Quote
Old 09-13-2008, 05:38 AM   #8
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
i agree with thomasnchy But if you try fix in a can stay with a name brand such as lucas i have seen the no name brands swell seals as much as four times the original size
PAPA BEAR is offline   Reply With Quote
radiator leak stelmadl Chevy Truck Forum 25 08-31-2008 10:39 AM
Radiator fan dogsrme GMC Truck Forum 4 08-16-2007 09:38 AM
oil in radiator??? s-dimeblaze-her Chevy Truck Forum 9 09-16-2006 08:37 AM
radiator fatboi Chevy Truck Forum 7 09-15-2006 07:20 PM
Hazardous Leak At Truck Stop Forces Evacuation (WRAL-TV 5 Raleigh) trucknews Truck News (headlines) 0 04-01-2005 08:30 AM
