| Banned Join Date: Nov 2008
| Fluid Capacities If anyone wants the fluid capacity specs for there trucks/cars. Just let me know. I can get most of that type of info. The more info you give me (year, make, model, engine, trans, 4WD or 2WD, etc..) the easier it is on me. Thanks! My trucks; Silverado (in bold) all options shown; CAPACITIES Engine, with filter..........10.0 quarts Cooling System, AT Initial Fill..........22.0 quarts Cooling System, MT Initial Fill..........22.0 quarts Automatic Transmission, 4L80-E Initial Fill..........7.7 quarts Automatic Transmission, 1000 Initial Fill..........7.4 quarts Automatic Transmission, Total Fill 4 speed 4L80-E..........14.0 quarts 5 speed 1000..........13.0 quarts Manual Transmission, NV4500 ..........7.8 pints Manual Transmission, ZF S6-650..........13.0 pints Differential, 8.25 ring gear Amer Front..........3.6 pints Differential, American 9.25 ring gear Front..........3.6 pints Differential, American 8.5 ring gear Rear..........4.2 pints Differential, American 8.6 ring gear Rear..........4.2 pints Differential, with 10.5 ring gear Amer Rear..........5.5 pints Differential, with 11 ring gear Dana Rear..........8.4 pints Differential, with 11.5 ring gear Rear..........7.6 pints Differential, with 9.5 ring gear Amer Rear..........5.5 pints Differential, with 9.75 ring gear Rear..........5.9 pints Transfer Case,NV236/246..........4.0 pints Transfer Case,NV261/263..........4.0 pints Transfer Case,NV149..........4.4 pints After refill check oil level. TORQUES Oil Drain Plug.....26 ft-lbs Manual Transmission NV4500 Fill Plug.....27 ft-lbs Drain Plug.....27 ft-lbs Manual Transmission ZF S6-650 Fill Plug.....26 ft-lbs Drain Plug.....26 ft-lbs After refill check oil level. Suburban (in bold) all options shown; CAPACITIES Engine, with filter..........5.0 quarts Cooling System, with AC Initial Fill..........20.0 quarts Cooling System, W/O AC Initial Fill..........17.0 quarts Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts Automatic Transmission, 4L80-E Initial Fill..........7.7 quarts Automatic Transmission, Total Fill 4 speed 4L60-E..........11.0 quarts 4 speed 4L80-E..........14.0 quarts Differential, Front..........3.6 pints Differential, with 10.5 ring gear Dana Rear..........5.5 pints Differential, with 10.5 ring gear EX Dana Rear..........6.3 pints Differential, with 11 ring gear Dana Rear..........8.4 pints Differential, with 8.5, 8-5/8 ring gear Rear..........4.2 pints Differential, with 9.5 ring gear Rear..........5.5 pints Differential, with 9.75 ring gear Rear..........5.5 pints Transfer Case,BW4470..........3.2 pints Transfer Case,BW1370/4401..........3.2 pints Transfer Case,NP241/NP243..........4.4 pints After refill check oil level. TORQUES Oil Drain Plug.....18 ft-lbs Transfer case NP241, 243 Fill Plug.....35 ft-lbs Drain Plug.....35 ft-lbs Transfer case BW Fill Plug.....18 ft-lbs Drain Plug.....18 ft-lbs After refill check oil level. |
| Tags |
| capacity, fluid |
| fluid ??? on transmission | BLK1500 | Chevy Truck Forum | 1 | 06-28-2008 08:07 PM |
| Transmission Fluid (for '75)? | Tangent | Chevy Truck Forum | 4 | 12-20-2007 08:53 AM |
| Brake fluid tip | chevyguy | General Truck Forum | 4 | 03-20-2007 08:43 AM |
| How much tranny fluid ??? | 84sierra | GMC Truck Forum | 7 | 03-18-2006 11:11 PM |
| A brief primer on pickup truck payload capacities (Autoblog) | trucknews | Truck News (headlines) | 0 | 09-27-2005 03:30 PM |
