| Senior Member Join Date: Jun 2008
| wet floor mat and padding my truck has a rubber mat instead of carpeting and my heater core was leaking into the cab, it dripped down behind the mat and soaked into the padding. i removed the mat and padding, flushed out the antifreeze with clean water and let it dry for a couple days in the sun. will it still have a musty smell after i re-install it? should i spray something on it 1st? any tricks? |
| I would replace the padding
| That padding will more than likely hold in the moisture and start smelling. It's hard to get moisture out of the padding. I bought a crown vic a while back that was "coffee logged". I took the padding out and washed the floor and let dry and reinstalled new padding and carpet. It was fine then. Hope this helps. |
| good clean outside air will take care of it most likely.... let it air dry as long or often as possible
| Rebuilding a floor jack????? | Lonesome7.3 | Off-Topic | 16 | 05-09-2009 09:48 AM |
| No Floor Heat | davefan360 | GMC Truck Forum | 11 | 01-05-2009 09:16 AM |
| Floor boards | schweikertcharl | Chevy Truck Forum | 4 | 08-05-2008 05:38 PM |
| Floor Heater Actuator | Brazzy | Chevy Truck Forum | 5 | 05-22-2007 11:48 AM |
| floor shifters | shane dill | GMC Truck Forum | 5 | 01-23-2006 09:17 PM |
