Old 11-05-2009, 07:02 PM   #31
today's progress
Old 11-05-2009, 07:05 PM   #32
ewww!!!! i have known a few peoples cooking that turned out like that. they had the same fate too.
Old 11-05-2009, 08:33 PM   #33
hotrodpc's Avatar
Is this the donor motor Mud??? Maybe a little bit of damage from Orange stuff???
Old 11-05-2009, 08:38 PM   #34
yep, donor motor. 90% is getting new gaskets over the weekend, then the transplant is a go for monday.
Old 11-05-2009, 08:43 PM   #35
hotrodpc's Avatar
Cool. Ought to be a good runner. I am sure I don't need to tell you. You already know. Use the GREEN antifreeze not the Orange junk.
Old 11-05-2009, 08:53 PM   #36
orange junk as in dex-cool or the universal coolant?
Old 11-05-2009, 09:05 PM   #37
hotrodpc's Avatar
Yes, that is what I am reffering to. You are using conventional Green going back together I assume?
Old 11-06-2009, 07:59 AM   #38
Crmzendrgone's Avatar
Crmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant future
That looks pretty nasty. Glad your doing some clean up work before throwing it in the Blazer.
What is your experiences with the green vs. orange(red depends on the brand). I have been told that the orange is better as far as last longer the only issue with the orange is gaskets and all, that is when people mix the antifreeze or buy that mix that says you can use it on either one. Or the water they use. I was told if you are going to use the different color that you need to flush the system WELL or the proper way would be to replace the gaskets in the engine but who wants to do that. At least that is what they taught at my vocational school.
Old 11-06-2009, 08:09 AM   #39
Wyley87's Avatar
Wyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to behold
if you get the good stuff green offers the same 5 year 100,000 mile (not sure on actual years or miles but i know its the same) as dex-cool. Also green is more readily available. I've always had a mental picture of being out if the middle of nowhere, perhaps Arizona running dexcool and my engine over heats loosing most of my coolant only to find that the local parts house only has green (which you can't mix the two).
96 GMC C1500 305 2WD
K&N FIPK C.A.I.
Rebuilt Motor and Trans
Mobil 1 15w50/Mobil 1 Filter
05 Nissan Xterra 4.0 V6
Royal Purple 5w30/Mobil 1 Filter
Cost money to go fast...How fast do you wanna go?
Wyley87 is offline   Reply With Quote
Old 11-06-2009, 08:25 AM   #40
hotrodpc's Avatar
The orange is only better because it apparently lasts longer. THATS IT. Otherwise, more harm than good in my opinion. This was GM's answer to a 100,000 mile maintenance free engine with exception of oil changes. I usually kept the Dex Cool in since the vehicle was udner manufactuer warranty. If I kept it lone enough to go out of warranty, then I changed it to the Green on some day at my leisure when I felt energetic and needed a reason to be outside.
engine swap monkeysport2k4 Chevy Truck Forum 3 08-17-2009 08:20 PM
5.3 engine swap? ghost4570 Chevy Truck Forum 0 08-15-2009 04:40 PM
engine swap bikernut Chevy Truck Forum 5 08-12-2009 08:52 PM
6 for 8 engine swap coltstrader Dodge Truck Forum 5 02-17-2009 03:12 PM
Engine swap AndyinCt. Chevy Truck Forum 5 07-01-2008 07:28 PM
