Old 10-30-2009, 05:24 PM   #1
peba's Avatar
peba is on a distinguished road
hydraulic brakes on trailer qeustion
will a trailer with hydraulic brakes have a different adapter or the same seven prong adapter?
2004 silverado z71 exhaust, cold air intake, 32 mud tires , 8mm spark plug wires
peba is offline   Reply With Quote
Old 10-30-2009, 05:28 PM   #2
BernieB's Avatar
It'll be standard seven pin I believe.
Old 10-30-2009, 05:46 PM   #3
most use a seven pin round, but the trailer does not have anything hooked to the brake terminal
Old 11-09-2009, 11:13 AM   #4
chevyguy's Avatar
Most hydraulis systems work of surge, No extra wires, If the trailer pushes forward on the coupler it applies the brakes itself.
USMC 92-96 USCG 98 to present
Old 11-09-2009, 01:57 PM   #5
BernieB's Avatar
Right, but trailers that size usually use the 7 pin because it's the default standard for larger trailers.
Old 11-09-2009, 04:00 PM   #6
there is no need for a 7 pin without the trailer brakes, so a 4 pin wouldn't be out of the question.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 11-09-2009, 04:48 PM   #7
my truck is wired with a seven, the boat trailer i have is hydraulic brakes, and wired with a 4 flat.....I use an adapter!
Old 11-09-2009, 04:53 PM   #8
BernieB's Avatar
No, a four isn't out of the question, but often times trailers large enough to require brakes also have reverse lights or batteries that need charging, and that's done with a seven pin.
Old 11-09-2009, 05:37 PM   #9
chevyguy's Avatar
Agreed with all, As long as he has a 7 to 4 adapter he will be good to go either way.
Old 11-09-2009, 08:06 PM   #10
also depends on the trailer size. Some of the larger 40' gooseneck, or heavy rated shorter trailers will use electric over hydraulic for the brakes instead of just electric or surge (which only works on bumper pull)
trailer size really doesn't matter on smaller trailers. some could have a 7 pin plug for just brake and turn lights etc.. just depends on how it was wired from the factory or the previous owner...
Hydraulic Brake Problems -- New to Me lobo Chevy Truck Forum 3 10-25-2009 10:11 PM
ABS Hydraulic Unit runs continuously mack1001 GMC Truck Forum 11 10-23-2009 01:23 PM
Hydraulic Clutch Problems Catstorman Dodge Truck Forum 3 01-05-2007 01:55 PM
06 Sierra trailer brakes help 01chevsilv GMC Truck Forum 4 04-21-2006 09:30 PM
Electric trailer brakes Bootlover GMC Truck Forum 2 02-10-2006 04:43 PM
