Old 08-08-2006, 02:27 PM   #1
mochester is on a distinguished road
engine squeaks when i turn it off
My engine seems to let out a 'squeak' during its last turn when i turn off the ignition. What could this be? anything to worry about?
mochester is offline   Reply With Quote
Old 08-08-2006, 05:26 PM   #2
most squeaks i have delt with end up being old belts. does it do it when you rev the engine
i'd rather be hunting
Old 08-08-2006, 06:18 PM   #3
no, nothing when i rev, just that one last turn when i turn it off
ill check out the visible belts...are there more belts inside that i won't be able to see?
yeah the two up front appear to be in pretty good condition, but i don't know if those are the ones you're talking about
Old 08-09-2006, 06:04 AM   #4
yeah those are the only belts. if you rub your fingers over the belts and alot of material comes off then you can get some belt dressing at your local auto store, helps restore the condition of the belts. if every thing checks out then i would look at your alternator, could be a bad bearing making the squealing.
Old 08-13-2006, 02:46 PM   #5
Larry O'Daniel's Avatar
Larry O'Daniel is on a distinguished road
When you look at the belts, see if you have the serpentine type that have the little ribs on the inside. The little ribs are actually tiny "V" grooves just like the onld V belts of old. When the serpentine gets old the little "Vs" are bottoming in their grooves just as the old V belt would bottom and squeek. Look at the belt, if the tops of the ribs are old and the bottom of the ribs (on the belt) is clean then it is bottoming and needs replacing. Likewise if the grooves are clean or black in the bottom and the tops are rusty, then replace the belt. They get old, dry out, bottom and squeek. Just as Mudseeker said, a belt dressing will help stop the squeek. Unfortunatly if the belt is wore out, then.... If the belt looks ok, check the belt tensioner pulley, the bearings could be going out and giving you the "last" squeek" when you shut down. Hope this helps.
Larry O'Daniel is offline   Reply With Quote
WTB 3.0 v6 for a 92runner jvmin Truck Classifieds 15 07-18-2006 06:57 AM
Carb to TBI engine swap klink70 Chevy Truck Forum 5 02-17-2006 10:54 AM
Engine Identified! Anyone know specs? klink70 Chevy Truck Forum 1 01-30-2006 10:07 PM
1993 Ford ranger turn signal problems 72'CaminoKid Ford Truck Forum 1 08-05-2005 08:22 AM
