Old 10-08-2006, 05:59 PM   #1
Willy.D. is on a distinguished road
Question pinging rattle from 5.7 eng.
While I was Cleaning the injectors on my "91"chev scottsdale at the side of the road in the dark somthing must have fallen in to the carb and is now bounceing around my engine.What is the best plan of action to remove this forien object?
Willy.D. is offline   Reply With Quote
Old 10-09-2006, 07:03 AM   #2
posted in chevy section.
i'd rather be hunting
Old 10-09-2006, 07:54 AM   #3
I think I should probly just drain all the oil instead,see if that gets it out .
Thanks anyway.
P.S. She's a looker!
Old 10-09-2006, 05:23 PM   #4
there is no way the object could have got in the oil if it fell in the intake. fuel, coolant and oil do not mix in the engine. i still say it is your lifters or you forot to tighten your air cleaner or something and it is rattling around.
Old 10-10-2006, 08:44 PM   #5
chevyguy's Avatar
You need to remove the intake if something is bouncing around. If it gets into the cylinder your probally gonna need a new motor. I wouldnt drive ti at all till i could pull the intake.
USMC 92-96 USCG 98 to present
Old 10-10-2006, 11:32 PM   #6
Kinda wondering how you were cleaning injectors in the dark, on the side of the road? Or, even why? This is a TBI motor right? (no carb)
If something small enough fell into the TB, and found its way through the plenum, it would have found a valve by now, and the conversation would more than likely be regarding why your truck will no lomger run. More importantly, the big question would be, "why did my truck stop running, after that terrible noise?" You should know, that the path of a foriegn object through the intake, would mean that 1 of the pistons took several shots at the object before you even realized it. A small noise may have been there for many miles. This does not mean all is well, just that the noise you hear now, may not be related to the object you think may have fallen into the engine.
Old 10-12-2006, 06:14 PM   #7
My truck is still running, but the noise steadaily increased to the point I won't drive it for faer of damage.
Octane booster clogged my injectors.
rattle noise when driving fordbigman Ford Truck Forum 7 09-15-2006 06:34 PM
Heat shield rattle 22re mochester Toyota Truck Forum 5 06-15-2006 01:10 PM
pinging and oil use 396chevy Chevy Truck Forum 2 02-10-2006 06:23 PM
93 Full Size Rattle xjcamaro89 Chevy Truck Forum 2 12-01-2004 03:10 PM
