| ok, since i got a set of free heads off my brother recently i decided to start up the engine build again(2 years going!?). anyways, i ran the cast numbers just a minute ago. 376450, from a 305 with a 60 cc chamber. the heads i have for the engine are for a 350 with a 76 cc chamber, 333882. my question is which heads should i use? right now the block is a 350 bored out .020 and has hypertatecticsomethingortheother flat top pistons waiting to be installed. i am not sure of the deck hieght at the moment. so how will the heads effect my compression and the ponies i get out of the engine??
| | #2 | |
I'd go with the 76cc head. That flat top piston with the 60cc will bring your cr too high meaning you're going to need a radical cam. Find out about that deck height and check it with the cr calculator at Wallaceracing.com/calculators just to get an idea. Forgot to mention this, 9.5:1 is the max I'd go with today's gas. Something in the 9ish is good.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed Last edited by Chevy808; 12-21-2006 at 10:45 PM. | |
| 76 Chevy 454 - massive oil leak in rear of engine | MrDavidOgle | Chevy Truck Forum | 22 | 06-24-2009 08:03 PM |
| How best to remove 1972 Chevy 4x4 engine? | rstricklin | Chevy Truck Forum | 3 | 08-27-2006 05:36 AM |
| WTB 3.0 v6 for a 92runner | jvmin | Truck Classifieds | 15 | 07-18-2006 06:57 AM |
| Engine Identified! Anyone know specs? | klink70 | Chevy Truck Forum | 1 | 01-30-2006 10:07 PM |
