Old 09-18-2007, 12:46 PM   #1
tdaly is on a distinguished road
Crazy Gauges
2002 GMC Ext Cab 145,000 miles Instrument panel and gauges begin to fall to zero and bounce back to normal while traveling. There is no problem with the performanceof the truck while this is occcuring, only the gauges falling and the warning lights coming on and going off.
Any ideas?
Thanx
tdaly is offline   Reply With Quote
Old 09-18-2007, 02:48 PM   #2
Welcome to the forum tdaly
Which engine do you have ?
Which gauges are effected ? Volts too ?
Which warning lites are coming on ?
Are they blinking or are you having several repeated events one after another that is gauge drop + lite on, then ok, then bad again ?
Give us more to work with and we'll do better.
Old 09-18-2007, 02:57 PM   #3
The engine is the small V-8 (327) I think.
All of the gauges are effected. Speed, Tach, Oil Pres., etc.
There are several lights that are coming on when this happens.
If you give me an email address I can send a video clip from a cell phone that my son took while he was driving and this was happening.
tdaly@venture-transport.com
Thanx
Old 09-18-2007, 03:19 PM   #4
That's pretty cool, we usually don't get vid, like the 6 oclock news
Can you post it on photobucket and post a link here ? That way everyone can see it.
Should be easy to do but if it becomes a problem let me know and I'll get it put up for you.
Old 09-18-2007, 04:17 PM   #5
Please see the attached link where you will find the video of the problem that we discussed.
http://s216.photobucket.com/albums/c.../?action=remix
Old 09-18-2007, 05:07 PM   #6
Moderator
link no worky
http://s216.photobucket.com/albums/cc37/tdaly_bucket/
fixed it
Old 09-18-2007, 05:11 PM   #7
Moderator
wow thats wierd. I wonder if there is a bad ground or maybe the plug is coming loose or getting a bad connection.
I know there have been problems with the gauge cluster going bad but i don't know if that included all the lights flickering too.
Old 09-19-2007, 12:09 PM   #8
using JW's link ok
or really full size
http://s216.photobucket.com/player.s...fs=1&os=1&ap=1
It seems like ign turns off then it tries to come back on with the bulb check.
Check if turn signals work when gauges drop.
Check if radio goes off at that time.
Check if heater blower goes off at that time.
This wil help isolate to key or computer problem.
Old 09-19-2007, 02:50 PM   #9
Moostang's Avatar
I would really have to go with loose wire under the dash.. I alway suspect a ground since most of the wires will usually share the same ground.....but the fact you have it on video for us... that rocks!
MEOW!!
Old 09-21-2007, 03:57 PM   #10
chevyguy's Avatar
You have a weak ground somewhere. Time to go at it with a meter.
crazy barn parties!! PickUpGirl787 Off-Topic 82 07-09-2007 11:54 AM
Idiot lights vs gauges jestructure Chevy Truck Forum 6 05-04-2007 03:25 PM
crazy idle johnmvtv Ford Truck Forum 5 12-26-2006 12:34 PM
speedometer and tach gauges boucing around 95champion Chevy Truck Forum 1 06-26-2006 10:50 AM
Gauges akemeny Ford Truck Forum 2 03-29-2006 07:55 PM
