| My truck is sluggish at wide open throttle. 88 GMC 1500 pickup 2 wheel drive V8 5.0L/305 Ok aside from it being sluggish because of the 305, what do you think the problem is. Here's what i did before this started: I needed to replace my exhaust flange gaskets where the y-pipe meets the manifolds. I snapped two of the bolts on the passanger side and could not drill them out so i decided to take the passanger manifold off so i can work on it like a gentleman. Well in an effort to get the manifold out of the truck, it was a bit of a struggle because the smog stuff was in the way. So, i just took the sawzall and cut all the smog stuff out of the way. After reinstalling the manifold, i plugged all vacuum lines and crimped those 2 silver pipes closed. The smog pump is still blowing air out the top of itself, i figured that doesn't need to be plugged. What would be causing the sluggishness. Does this truck have a computer to program the smog out or what? Was i supposed to crimp those lines closed? Thanks for any help guys. |
| Senior Member Join Date: Dec 2006 Location: Illinois
| same truck same year same problem! I want help too
__________________ Ashley My first truck was a 1988 Chevy 1500 with the 305 My new truck is a 1997 GMC 1500 with the 350 |
| well does yours die when you try to accellerate? becasue I am sure that we can brag about whose truck is the worst all night
| Senior Member Join Date: Jun 2007 Location: Central Pennsylvania
| You can expect the engine not to run properly when you damage the "smog stuff". Its actually important to have this hooked up. Your best bet is to repair whatever damage you did. It is hooked into the trucks brainbox, and eventually it will register a service engine light. I had a Beretta that did the same thing when I messed with the emissions equipment.
__________________ Tractors are like watermelon, you keep the red and throw away the green." |
| | #6 | |
| Take it to a Dealer, they'll do it for ya.
| Sounds like it could be running too rich... OR it could be one of a million other things... sensors, etc.
| Help a Student..Take a Truck Survey | ClassSurvey | General Truck Forum | 2 | 12-08-2007 06:51 PM |
| Rush Enterprises to Open a New State-of-the-Art, Full-Service Truck Dealership in the Nashville Area (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 09-09-2005 01:30 AM |
| Rush Truck Center, Nashville, Set to Open Oct. 7 (TruckingInfo.com) | trucknews | Truck News (headlines) | 0 | 08-19-2005 01:30 AM |
| KamAZ to open truck assembly plant in Egypt (Itar-Tass) | trucknews | Truck News (headlines) | 0 | 04-29-2005 09:30 AM |
| MRD Motorsports Announces Open Wheel Ace Jimmy Kite to Drive NASCAR Truck (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 03-09-2005 05:30 PM |
