| Oxygen sensor on 2002 2500 HD How does the O2 sensor effect the motor and is there anyway to bypass it. I was told that "modifying the Converter" would help performance and mileage on a 6.0. I have noticed that the exhaust has an O2 sensor on the backside of the converter. |
| it tells the comp. how lean or rich to make the motor run. i think your truck should have 3 or 4 o2 sencors
| Senior Member Join Date: Nov 2005 Location: Grand Rapids, MI
| I believe the first one tells the computer how the engine is running. The second (after the converter) tells you if the converter is doing it's job. I know you can eliminate the converter, but then you'll have to replace your (second) O2 sensor(s) with an O2 simulator so you don't get the warning/ check engine light. I don't think "modifying" or eliminating the converter is going to get you any significant gains. I'd leave it. |
| Keyless entry intermittant working 2002 Astro van | amanda11270 | Chevy Truck Forum | 1 | 06-11-2007 07:40 PM |
| 2002 2500 hd chrome bumper | mattyd | GMC Truck Forum | 2 | 01-17-2007 09:27 AM |
| 2002 2500 4x4 lowering? | Robert78.5 | Dodge Truck Forum | 10 | 12-11-2006 05:35 PM |
