Old 10-28-2007, 06:28 PM   #1
pvtjoker is on a distinguished road
cannot find oil pressure sending unit...
i'm wanting to replace my oil pressure sending unit...i cannot find it's location on my truck...i have a 92 GMC 1500 4x4 p/u w/ a 305 v8...
thank you
pvtjoker is offline   Reply With Quote
Old 10-28-2007, 07:54 PM   #2
scavanger's Avatar
scavanger is just really nicescavanger is just really nicescavanger is just really nicescavanger is just really nicescavanger is just really nice
I think it should be next to the dist. just behind the intake. Drivers side of dist.
Scavanger
Old 10-28-2007, 08:35 PM   #3
tjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud of
Either there of right above the oil filter on the block
Old 11-03-2007, 09:26 PM   #4
brutis's Avatar
brutis is on a distinguished road
on a 454 it's on the drivers side right under the power sterring pump back a little on the block
brutis is offline   Reply With Quote
Old 11-03-2007, 09:49 PM   #5
chengny's Avatar
chengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud ofchengny has much to be proud of
There is a little Christmas Tree arrangement behind/under the distributor. It taps the oil system at the top of the block. A simple 1/8" NPT tee/nipple combo. If you have an actual oil pressure gauge on your dash, there will be a diaphram actuated rheostat with one electrical lead attached (usually on the passenger side) to one side of the tee. The other side accepts a make/break switch (two leads)for an low lube oil prsssure warning light on the dash. Even if you have a gauge the other switch must be left in place. It is incorporated into the choke system.
Just pop the dist cap and unscrew the affected switch. Make it up with a tiny bit of teflon tape, and resist the urge to overtighten. It won't leak - even if it does, it is easier to go back and tighten further than replace a sheared pipe fitting (esp. the one in the block).
chengny is offline   Reply With Quote
Temperature sending unit location nnunez Toyota Truck Forum 4 10-15-2007 07:45 AM
Oil Pressure waterloo88chev Chevy Truck Forum 3 07-16-2007 10:39 PM
In-tank Sending Unit Removal Question. J-Bob Bigz Chevy Truck Forum 6 12-07-2006 08:42 AM
fuel sending unit ? outdoorsman Toyota Truck Forum 4 09-13-2006 01:41 AM
help on fuel sending unit utah86gmc Chevy Truck Forum 6 03-30-2006 10:16 PM
