| Full Member Join Date: Oct 2007
| new holley hi im not sure if this is double posting as i have posted another question today. (if so im sorry) i just put a new 750 holley on today and i hooked up the vaccume advance on the distributor and the vaccume to the brakes but there is another vaccume port in front of the throttle body what does this go to? also to hook up the modulator vaccume on my th 400 do i hook that directly to the nipple coming off my manifold behind the carb? thanks in advance!
__________________ Cash, Grass Or Gas, No One Rides For Free !!!!! |
| Trans modulator line goes direct to intake. Most of the time the dist advance is hooked to a port above the throttle plates. I have hooked them to intake but you could get some pinging doing that . I would have to guess that the port on the throttle plate is for the dist. advance. scavanger |
| The one on the front of the plate is for the PCV valve if it`s a 3/8 hose fitting. |
| the one on the side by the choke cable lock is for distributor its labled, but thanks for the info got all i need now. unless someone can tell me how i can get wheel lifting launches out of a 350 in my truck??????????
| oh i have a 750 holley on my 350 chevy and when i nail it it falls on its face, is this because the carb is too big?
| if you have a 350 that has not been bored or nothing done to the heads, 750 is alot more than that engine requires. cant tell you exactly if that is your problem as i do not know what all you have. |
| the 350 is a standard bore with flat top pistons, full length race headers flowmaster 40 series mufflers and thats about it
| 650 cfm is plenty for that set up. |
| will a 650 still do once i get my weiand stealth air strike intake,and some roller rockers?
| 650 should be good up to around 350 horse or so on a small block. Unless you go to a stroker with big heads it should be fine. |
| Tuning a Holley Carb? Anyone know how? | Bowtie Blitz | Chevy Truck Forum | 6 | 05-18-2007 01:19 PM |
| holley tbi | 396chevy | Chevy Truck Forum | 1 | 08-30-2006 01:27 PM |
| 78 chevy 350 2bbl holley | southern rebel | Chevy Truck Forum | 1 | 07-03-2006 09:33 PM |
| polished holley 600 CFM Carb. elec choke | chevyguy | Truck Classifieds | 8 | 06-21-2006 02:33 PM |
| Carb Info? | great_beer_man | General Truck Forum | 14 | 05-30-2006 10:14 AM |
