Old 11-17-2007, 08:49 AM   #1
robert d is on a distinguished road
electrical problems
I have a 85 GMC 3/4 ton the problem I'm having is the rear tail lights one minute they will work and the next minute they don't nothing at all but if I shake the back of the truck they will come on and if I keep doin it they will flicker i don't know were to start .
robert d is offline   Reply With Quote
Old 11-17-2007, 02:39 PM   #2
Hayden's Avatar
follow the wires from the lights to the front.. I bet they're shorting out on the box or frame. shouldn't be a hard fix
Old 11-17-2007, 03:34 PM   #3
scottie's Avatar
i bet its just a loose or corroded connector behind the light assembly, pull it off clean it and put it back on, it should would. if it were a short, it would be blowing a fuse, so i bet it is a loose connector
Old 11-18-2007, 07:50 AM   #4
actually, if the short were after the load (tail light), i believe the lights would still work and not blow a fuse. before the load would be a different story.
Old 11-19-2007, 04:55 PM   #5
Welcome to the forum robert d.
Think you might have read that wrong. Fuse idea was related to before the lamp, so was right.
Grounds going bad on a truck that age is common, so check connector as suggested
but if both sides failing together is more likely the ground to frame at rear of truck.
To be sure that is the problem if you don't see it right away, take off a lamp fixture but don't disconnect wires.
Shake truck to get failure and while bad, use a jumper to a GOOD ground
or check voltage to good ground. Be sure which side of lamp is failing.
crabtruck is online now   Reply With Quote
Electrical problems, I think? Griffen85 Dodge Truck Forum 5 09-01-2007 08:22 PM
97 Dodge 1500 4 X 4 electrical problems Phil Herr Dodge Truck Forum 3 02-11-2007 08:58 PM
Electrical problems wileec Ford Truck Forum 11 01-05-2007 02:03 PM
'94 Suburban Electrical Problems cookcs Chevy Truck Forum 10 10-14-2006 06:56 AM
Odd Ball Electrical Problems! Rodeo Bo Ford Truck Forum 6 10-12-2006 07:27 AM
