Old 11-17-2007, 11:07 PM   #1
electrical nightmare
some of you may remember me mentioning my check gauge light problem. it seems to have gotten worse. it used to only happen at start up when cold out side. now it has showen up after many minutes on the road during normal operating temp. i thought it was a faulty temp sensor but todays events have me confused.
the light doe not flash or stay solid. it just flickers from 1 second up to 30 seconds.
it took about an hour but i got a vidio from my phone to the computer and finally to photobucket. enjoy.
i'd rather be hunting
Old 11-18-2007, 04:13 PM   #2
no one
Old 11-18-2007, 05:27 PM   #3
man I couldn't even begin where to think about looking. that is wierd...
Old 11-19-2007, 03:07 PM   #4
Hayden's Avatar
Did it start doing it after you added or modified anything. If so that'd be a good place to start. Hate to see something go wrong with winter coming upon us.
Old 11-19-2007, 03:21 PM   #5
been doing it ever since i overheated it twice during the winter. that's why i thought it was the temp sensor. it used to only do it at start up during cold wet mornings, now it's totally random and is getting worse.
my electrical instructor suggested a cracked circuit board.
Old 11-19-2007, 05:31 PM   #6
crabtruck's Avatar
You are getting some type of ground fault (not a hot short) between lamp and PCM.
Pull dash and inspect the trace from lamp to edge connector for possible bridge
from solder, debris, or even a bug (some can cunduct pretty good).
Also check wires from connector to PCM for abration damage.
Failing either of those, it's being generated through the PCM
and should show up through OBD-II info, likely in real time.
Old 11-20-2007, 11:34 AM   #7
i have run data stream info many times with the tech II at the shop and nothing seems to be out of spec.
but i can never get the light to come on when i am testing it. lol
once i find a wiring diagram i plan to pull the cluster out.
Old 11-20-2007, 01:47 PM   #8
crabtruck's Avatar
Don't need a wiring diagram to follow the trace, you would have to anyways.
Old 11-29-2007, 08:42 PM   #9
$150 later and the problem is fixed.
story first then i'll tell you guys the fix, or maybe i'll let you guess.
i was on my way to class on wed when the check gauge came on again,
this time the speedo started jumping along with the tach.
the gear indicator light would also dim at the same time.
once i got to town the speedo went from 35 to 65 twice then died
along with the tach and gear indicator. i wasn't too concerned at that point,
until i tried to climb up the school driveway,
no power at all. i pulled into a bay and pulled the codes,
had a few TCC codes and a 1-2 code and 3-2 code
p1860, p0740, p0753, p0758, p0785 for those who are curious.
lets see what you can come up with,. with the info i gave you
Old 11-29-2007, 09:06 PM   #10
crabtruck's Avatar
Based on the new symptoms being attributed to the old check lite thing, I'm going to guess VSS buffer problem. Was maybe gonna go with pcm but not likely. Too drugged out on cold meds to look up those codes. Secondary guess might be shorting TCC switch but that would not have played this way, other probmlesd. Ferschizle?
Tags
ignition switch, speedometer, tach, transmission, transmission codes
any suggestions? a nightmare indeed... MrMischief GMC Truck Forum 4 09-13-2007 07:07 PM
Electrical Nightmare Boat guy GMC Truck Forum 6 07-05-2007 08:10 PM
Bracket Nightmare BillySuburban GMC Truck Forum 5 03-09-2007 11:44 PM
tbi nightmare, carb swap? trans1973 GMC Truck Forum 8 03-08-2007 08:45 PM
code 43 nightmare Deltadog Chevy Truck Forum 1 05-30-2006 03:37 AM
