Old 11-22-2007, 02:28 PM   #1
joeydeherrera54's Avatar
joeydeherrera54 is on a distinguished road
83 gmc wont start
well i went out to start my truck and it started to turn over then it just stoped i checked the starter and that is good im thinking its the sensor for when you push the clutch down so does anyone know how to check that to see if its bad? or any other idea of what it could be
joeydeherrera54 is offline   Reply With Quote
Old 11-23-2007, 08:10 PM   #2
Graderman's Avatar
Graderman is on a distinguished road
When that happened to me it turned out to be a corroded battrey post. Just enough power to turn the motor over twice and then nothing.
Graderman is offline   Reply With Quote
Old 11-24-2007, 08:24 AM   #3
that what i thought to but i changed both of those and the wires because there were really bad but thats wasnt it. im sure it is the clutch safety switch i think thats what its called anyway
Old 11-27-2007, 06:32 PM   #4
I suggest you start with the key, making sure that's putting out the signal for the clutch switch.
Believe it's the yellow wire.
Then check if switch is receiving that signal and closing by checking the voltage at both sides.
Purple should be output.
There is a third wire (green and white) which goes to your manual tranny
and is connected with the yellow (key) wire.
Purple heads through firewall via eng harness connector and on to starter solenoid.
Should be able to check voltage at each of the points to see where failing if that is the problem.
Check that the switch is properly adjusted for pedal travel, so you know it's not failing because of poor mechanical contact.
With key off, you could ohm the switch looking for open and short while operating it by hand.
Simplest check: does system voltage drop when you try to crank ?
If it does, circuit is probably ok from key to switch to solenoid,
and starter/solenoid/wire connections become suspect.
Old 11-27-2007, 06:41 PM   #5
i figured it out it was the ignition switch that was bad i wasnt getting any power to the clutch safety switch so thank all of you for your help
Old 11-27-2007, 06:49 PM   #6
Glad you got it. Those switches go out just often enough to make them worth checking early in the process.
Old 11-27-2007, 07:54 PM   #7
tjzz4 is a glorious beacon of lighttjzz4 is a glorious beacon of lighttjzz4 is a glorious beacon of lighttjzz4 is a glorious beacon of lighttjzz4 is a glorious beacon of lighttjzz4 is a glorious beacon of light
hey Crab...
Old 11-28-2007, 04:30 PM   #8
More than one way to skin a cat tjzz4
truck wont start drewmowles Chevy Truck Forum 50 05-18-2007 02:32 PM
78 F-250 wont start this morning... milemaker13 Ford Truck Forum 3 03-03-2007 02:09 AM
Wont start blue cobra 60 Chevy Truck Forum 3 10-18-2006 10:24 PM
78' scottsdale wont start 92Jag Chevy Truck Forum 10 03-10-2006 12:22 AM
Explorer wont start DesertRacer Ford Truck Forum 0 11-13-2004 04:39 PM
