Old 12-01-2007, 03:52 PM   #11
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
1. fuel meter/sender b/o for guage
2. ign switch for trans problem, when acting up stop, turn off truck, restart and drive if o/k (trans loosing ign feed)
3. MAF sensor for poor acceleration/chugging, GM pumps whine quite abit normally, b/o pump usually long crank/no start (can't build pressure cranking) you should put guage on and tape to windshield then drive, be carefull a b/o MAF can fool you, a poor running engine will give erratic readings while driving. don't just change parts diagnose a little. mike
jimbo543 is offline   Reply With Quote
Old 12-01-2007, 04:07 PM   #12
if the tranny was not recieving info then i think it would throw a code but i could be wrong. i just replaced the ignition switch in my chevy 2 days ago because the tranny could not recieve info. the tranny was stuck in third gear and would only manually shift from 2nd to 3rd and vice versa.
do you have a check engine light lite? i would change the sloenoids.
Old 12-02-2007, 02:59 AM   #13
pike_mazter is on a distinguished road
No check engine lite came on. Slow exceleration shifts fine, when I slam it to the floor it sits at the same RPM but does not go into gear. I drove it around last night a bit and thats pretty much whats going on.
Got some nasty snow/ice last night and this morning on the way to work really did not have a chance to look it over any more.
pike_mazter is offline   Reply With Quote
Old 12-02-2007, 05:32 AM   #14
yeah, don't want to try kicking it down in the slop we got hit with, unless you like to be in the ditch.
Old 12-02-2007, 07:11 AM   #15
Oh I had some fun in the parking lot when I first got to work. That kind of stuff scares people around here.
Old 12-02-2007, 02:49 PM   #16
i know what you mean. i was passing people driving 35 down a 4 lane highway last night. if you can't handle your vehicle then you need to get out of everyone elses way.
Old 12-03-2007, 11:00 AM   #17
Talked with the dealership I bought it from today. Even though it was sold as is with no warranty they are willing to check over the fuel system and buy any replacement parts needed but they will not pay for installation. Funny thing is, they expect to be installing the parts and at least making some money off me, but I'm just taking the parts and running. I'm gonna see if they can check the tranny to even though I have pretty much ruled that out as a problem.
Old 12-03-2007, 01:12 PM   #18
take a different vehicle when you pick the parts up or they might try to block your truck in the lot. lol
Old 12-19-2007, 04:50 PM   #19
deoncollins69 is on a distinguished road
One indication of a bad pump is hard starts. My 98 whinned like crazy. On the other hand my 97 although a diifferent design pump, was very silent. I replaced both pumps. Also if you've ran it dry a couple times get ready to replace it. It does not like no fluid. they are cooled by the fule in the pump.
The tranny issue may also be from a shift kit improperly installed. Forget one spring or ball and you're done. Good luck
deoncollins69 is offline   Reply With Quote
Hi, New Ford owner here well it's an 83 duelly95 Ford Truck Forum 3 09-11-2006 06:50 AM
New Tundra owner tundrasaver Introductions 2 08-28-2006 08:27 AM
new truck owner 58 gmc Introductions 4 07-05-2006 12:57 PM
I need help new Ford owner 86F150 Ford Truck Forum 3 04-17-2006 02:36 PM
New Hybrid GMC owner rubenl Introductions 3 11-30-2005 02:08 AM
