Old 12-23-2007, 10:12 PM   #1
jacquesje83 is on a distinguished road
oil pressure
My oil pressure reads about 85 for around 6 minutes after starting truck before it will back down to 20 while at idle. During this time the truck make a soft squeeling noise. I realize the noise is not normal but what about the oil pressure? Its a 496.
jacquesje83 is offline   Reply With Quote
Old 12-24-2007, 02:33 AM   #2
Lets talk about what kind of truck you have a 496 CI engine in.
Is this simply a late model 8.1?
What type of oil are you running?
Do you believe the squeeling noise is related to any internal engine components?
Old 12-24-2007, 03:44 AM   #3
crabtruck's Avatar
Welcome (back) to the forum jacquesje83.
Is this the 2002 GMC Sierra 2500HD 4x4 LB W/ 8.1L/496 that you got back in October ?
Oil pressure sounds kinda normal behavior, does it kick back up with rpm ?
Old 12-24-2007, 10:09 AM   #4
It is the GMC Sierra 2500HD 4x4 LB W/8.1L/496. I'm not real positive about the oil type in the truck at the moment. It had an oil change right before I bought it and I have only put 1000 miles on it since. The oil level is fine and clean. The oil pressure usually flucuates with RPMs. sits at 20 until I'm moving then gets up to around 60 while I'm moving. The problem is that now it sits at the high pressure for a few minutes. While sitting still the engine is relatively quite. When I start to move the engine squeels then stops squeeling when I slow down until the pressure goes back to normal flucuations.
Old 12-24-2007, 07:26 PM   #5
Stoney's Avatar
Stoney is on a distinguished road
What weight oil are you using? I believe 5W-30 is the factory recommendation.
Peter
'03 Silverado 2500HD LS XC SB
8.1L/Allison 3.73LSD 4X4 3/3 drop
Stoney is offline   Reply With Quote
oil pressure question medic3616@sbcgl Chevy Truck Forum 11 02-09-2009 10:32 AM
back pressure pscheers Chevy Truck Forum 17 10-06-2007 09:09 AM
fuel pressure Hayden Chevy Truck Forum 2 09-29-2007 10:40 AM
Oil Pressure waterloo88chev Chevy Truck Forum 3 07-16-2007 11:39 PM
91 2.8 oil pressure rlarryg Chevy Truck Forum 0 12-05-2006 10:50 AM
