| Multiple Cylinder misfire My truck recently started acting up, a couple of times, when the motor was cold, it would not want to keep running, even dying a couple of times. After running for awhile it would run ok, (I have never thought it idled all that well). I took it in to have it checked out and it had "multiple cylinder misfire" I guess 4 of 8 cylinders must have misfired at the same time. I did tune it up this summer, plugs, wires, etc.. oh yeah it's a 99 GMC 4x4 4.8 liter auto. |
| who did you take it to? did they tell you the specific code? the codes would help out alot.
| Alot of intakes leaking vacuum when they are cold spray some carb cleaner around the base of the plastic intake on a cold moring to see if the idle changes if so need to replace the gskts |
| Senior Member Join Date: Jan 2008 Location: L-burg KY
| my former bosses truck (99 chevy 4wd 5.3) he had the same code turns out his #7 coil pack was misfiring. he replaced 3 of them to find it. |
| Full Member Join Date: Jan 2008 Location: Maine
| I'm going thru a "Random Misfire" problem right now too. Narrowed it down to a faulty fuel injector. Installing a new one tonight & hopefully it fixes the problem. I'm lucky enough to have a friend that can borrow a GM code reader / diagnostic computer. We could watch each cylinder as it fired or in the case of cylinder #1 didnt fire. The coil was working so that led us to the injector. Finding a cause of a misfire is not an easy job!
__________________ |
| #2 cylinder not getting gas | jesusdrivesagmc | Chevy Truck Forum | 3 | 11-09-2007 08:39 PM |
| MisFire!!! Ive tried everything, help. | jaime7818 | Toyota Truck Forum | 4 | 08-09-2007 08:11 PM |
| Multiple PM Emails | Ford4x4Chik27 | Forum Help | 6 | 07-20-2007 12:28 AM |
| Misfire on start | bmc257 | Chevy Truck Forum | 9 | 07-22-2006 10:17 PM |
| 1999 ck 1500 truck random misfire | Patrick | Chevy Truck Forum | 8 | 05-25-2006 10:19 AM |
