| Junior Member Join Date: Jan 2008
| Turn signal problem please help My 2001 2500 HD has a problem with the turn signels. The problem is that they blink on the guage center when you turn them on but the don't blink when you step on the brake pedal, they just stay on but don't blink. Any ideas what this could be I have no idea. Please help!!! Please help |
| I had the same problem in my 1995 s10, turned out to be the brake sensor right on the pedal. Not sure if it would be the same problem for you.
| Turn signal problem please help My 2001 2500 HD has a problem with the turn signels. The problem is that they blink on the guage center when you turn them on but the don't blink when you step on the brake pedal.They just stay lit but don't blink. Any ideas what this could be I have no idea. Please help!!! Please help |
| Did you know you posted this twice? Just curious. Computers can be a pain sometimes. And sometimes just double clicking can cause that. On the other thread I mentioned that I had a similar issue on my 1995 S10, turned out to be the brake light sensor right on the brake pedal. Might want to look at that. not sure if it is the same issue, but might work.
| sorry for the double post . |
| Senior Member Join Date: Dec 2007 Location: Alberta
| sounds like your brake lights are shorted to you signal, some how, |
| turn signal/hazard flasher relay location | basstracker | Mazda Truck Forum | 3 | 11-19-2007 09:04 PM |
| Any way to test a turn signal flasher? | gunner1 | Chevy Truck Forum | 4 | 02-09-2007 01:56 PM |
| Turn signal cancels daytime lights | TonyK | GMC Truck Forum | 7 | 10-24-2006 06:33 AM |
| turn signal switch | 79ford4x4 | Ford Truck Forum | 2 | 09-30-2006 07:26 AM |
