Old 03-01-2008, 05:34 PM   #11 (permalink)
dasafgmc68's Avatar
dasafgmc68 is on a distinguished road
timeserts
ok i watched the video on inserting timeserts and that is one of the problems i have ran into is not only the limited amount of space but i have to use or make a extention for every thing. but i will try them i'm going to go ahead and pull the trans tomorrow and see if that helps. I can't pull the motor or i would i'm sure it would make it alot easier to do it. but it will probably take to much time. I would take it to a repair shop but i'm in Arkansas and i will not have someone working on my truck that i don't know thanks for all your help guys i will post pictures soon
dasafgmc68 is offline   Reply With Quote
Old 03-01-2008, 06:57 PM   #12 (permalink)
Moderator
mrjohnwayne is a splendid one to beholdmrjohnwayne is a splendid one to beholdmrjohnwayne is a splendid one to beholdmrjohnwayne is a splendid one to beholdmrjohnwayne is a splendid one to beholdmrjohnwayne is a splendid one to beholdmrjohnwayne is a splendid one to behold
what is a time sert?
I've never seen em. It's looks similar to a heli coil.
Old 03-01-2008, 07:00 PM   #13 (permalink)
z07
z07's Avatar
z07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of light
They are similar.
I'm no mechanical engineer but to me a Helicoil is a spring while a Timesert is a threaded tube with threads on both the inside and outside.
Timesert:
Helicoil:
z07 is online now   Reply With Quote
Old 03-03-2008, 04:52 AM   #14 (permalink)
crabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to behold
Probably a good simple descirption would be a heli is a spring that gets compressed to the hole,
while the timesert is a tube that acts like a molley or concrete anchor bolt
by permenantly expanding on installation at the deep end.
Same job/function but the timesert has better odds of surviving in low strength holes.
No I didn't scientifically test that, just my near-humble opinion.
Old 03-03-2008, 07:18 AM   #15 (permalink)
gmctrucks is a name known to allgmctrucks is a name known to allgmctrucks is a name known to allgmctrucks is a name known to allgmctrucks is a name known to allgmctrucks is a name known to all
Can you weld a bolt in the block and use lock washer and good lock nut to hold it in place Hilicoil is a good idea how about re-tapping to a slightly bigger size just buy the right replacment bolt same grade. Let us know what route you took.
Old 03-03-2008, 04:11 PM   #16 (permalink)
dasafgmc68's Avatar
heli-coil/timeserts
I'll start with the helicoil firstly helicoil does not make an insert longer than 3/4 of an inch so it will not work the starter bolts are 1 1/4 inch long so i can't use them. the only way i have been able to find time serts is online through their website and the pdf will not load so I'm going to retry extracting it. I dropped my trans and my v-drive to give my more room to work but it's raining today and when it broke i was in the middle of a mud field so the tow-truck couldn't get it up my steep driveway into my garage so it's on the street in front of my house. but i will start first thing tomorrow after it dries up abit outside and will let you guys know how it goes. thanks again for all your help guys
das
Old 03-03-2008, 05:23 PM   #17 (permalink)
Good luck but remember to keep us posted it might happen to us one day.
Old 03-03-2008, 06:29 PM   #18 (permalink)
scavanger is on a distinguished road
I have never had much luck with the helicoils. they don't like to stay put. I think your much better off with the timesert. I have used something similar with good results.
Scavanger.
Old 04-05-2008, 07:30 PM   #19 (permalink)
dasafgmc68's Avatar
finished
Several things have been going on with this crazy truck but I've finally finished. Firstly i broke off an extractor bit inside of the bolt, if you've ever heard about that happening it's as bad as it sounds. I'm not sure what they are made of but any drill bit you can buy will not drill them out or even put a dent in them. I got tired of playing with that so i decided to just make a custom fit mounting bracket because there is an extra unused hole closer to the flywheel and I'm wrapping up the last of it right now. i had to take out the trans & transfer & all the wonderful **** that is attached. I must add that this was my first time doing this and it almost drove me crazy.
das
Old 04-05-2008, 08:37 PM   #20 (permalink)
Seems like you always run into the worst snags on the first go round, like picking on the new guy LOL
Broken Hazard Button usmceric1 Chevy Truck Forum 8 12-25-2007 10:31 AM
broken bolt jcold83 GMC Truck Forum 2 04-21-2007 08:40 PM
Please Help: broken glow plug wmiller Ford Truck Forum 2 02-13-2007 04:43 PM
1992 toyota p/u speedometer broken mochester Toyota Truck Forum 1 09-05-2006 09:40 PM
Broken truck from Broken Bow (Jefferson City News Tribune) trucknews Truck News (headlines) 0 05-17-2005 06:30 PM
