Old 03-02-2008, 01:29 PM   #1
rcarlos is on a distinguished road
rear end noise
only when i accelrate from bumper to bumpe traffic
rcarlos is offline   Reply With Quote
Old 03-02-2008, 05:10 PM   #2
stumpuller454's Avatar
can you explain the noise better? do you feel anything? could be a bad u-joint.
Old 03-02-2008, 06:34 PM   #3
2003 gmac sierra 4.8 160000 miles tranny running good mortor great car the noise be the rear axle
Old 03-02-2008, 06:36 PM   #4
Old 03-02-2008, 08:19 PM   #5
keithr0005005's Avatar
well if the noise be the rear axle than that be your problem. go buy a replacement.
Old 03-03-2008, 08:21 AM   #6
Make sure the transmission yoke doesn't need to be repacked with grease try that first it's the cheapest thing to do it can fool you good.
Old 03-05-2008, 04:29 PM   #7
Question sierra 1500 160000 miles & still going
only thing replaced belts battery plugs carstro oil over mileage
do i need to change filter on tranny now
Old 03-06-2008, 11:43 AM   #8
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
is it 2wd or 4wd?
if 4wd flush transmission&replace filter, drain/refill t-case(autotrack or atf), drain/refill front diff(80w90 or 75w90 syn), drain/refill rear diff(75w90 syn).
if 2wd flush transmssion&replace filter, drain/refill rear diff(75w90 syn)
jimbo543 is offline   Reply With Quote
Old 03-06-2008, 08:21 PM   #9
72'CaminoKid's Avatar
check your u joints first. sounds like that might be the issue
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 03-06-2008, 10:39 PM   #10
junior3382's Avatar
I agree with Camino. Have thought that since I first saw this thread. Most little clanks and bangs in the rear are either u-joints or bearings. I would check the universal joints first and work out from there.
If you have 160k on it and have not replaced the tranny filter and fluid, then yeah, definitely do that, but that is not nescesarily going to solve your problem here.
Rear end whirring noise - coasting 45 down Myersld GMC Truck Forum 2 11-16-2007 02:42 PM
Clunck noise from rear of truck irazu GMC Truck Forum 10 08-06-2007 09:02 AM
Squeaking noise comming from rear end? TopCal2500hd GMC Truck Forum 1 02-22-2007 09:03 PM
Noise from rear end Itstali25 Chevy Truck Forum 6 10-24-2005 09:31 AM
The vehicle, an lder sedan, slid under the rear of the truck and was crushed as far back as the rear (Chico Enterprise-Record) trucknews Truck News (headlines) 0 09-30-2005 01:30 AM
