Old 03-06-2008, 12:28 PM   #1
OssipeeSteve is on a distinguished road
'97 GMC overdrive intermitent
Usually goes into OD @ 40 MPH. Now it may not until 60 MPH after 5 miles travel, then I set Cruise Control. It may then several miles later fall out of overdrive and cruise drops off. I changed Throttle Position Sensor. No Change. Tranny shifts smoothly in all gears, up and down, even when falling out of OD. Would appreciate any comments. Truck well cared for. 125K miles.
OssipeeSteve is offline   Reply With Quote
Old 03-06-2008, 01:12 PM   #2
check and see if your distributer has a small pickup switch(like a murphy switch) in the base. My 91 had it at about 130,000 mi, the lower bushing in the distributer went bad and would not keep the switch made up. put a rebuilt dist in and all has been good for 50,000 mi.
I thought it was major tranny work dropped it off, the wrench in the tranny side of the shop coudn't find anything with a filter change, The wrench on the mechanical side of the shop found it as hae had seen it once before.
good luck
Old 03-06-2008, 01:20 PM   #3
That's interesting. The distributor crossed my mind but it was not something like that. I'll look for something there. You say"Murphy Switch", and I have no idea what you mean. Can you clarify?
Thanks.
Old 03-08-2008, 10:10 AM   #4
Its a makeup switch, Look up your distibuter online (like parts america) if it has 2 connectors the small one is for the tranny
Old 03-10-2008, 06:58 PM   #5
Thank you. In the interim, I cleaned the connector at the Vehicle Speed Sensor before I read your response, which does in fact control the Cruise and Torque Converter Clutch, the issues I'm having with the truck. I did put a new cap and rotor on yesterday and ran today with no troubles for 30+ miles until, ya, you guessed it, Cruise dropped off and I lost Overdrive. Mind you I probably did touch that connector at the distributor you spoke of. I'll get into it in the AM. I took an Ohm reading on the VSS hot as it may be faulty hot/ not cold. I'll see what the ohms are in the AM.
Thanks again,
Steve
Old 03-11-2008, 01:08 AM   #6
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
how bout brake switch, does trans act up with cruise off?
sounds like cruise is cutting out causing throttle to drop off cutting tcc and od.
check brake switch cruise switch
jimbo543 is offline   Reply With Quote
Old 03-11-2008, 06:46 PM   #7
Cruise will not operate when overdrive will not engage. That's not to say the switch isn't always knocking it off, huh? But I think I've run that truck in Cruise below OD speeds. I did check ohms on vss this AM and they matched the part at the store so it's unlikely to be the vehicle speed sensor. There is one three wire connector on the distributor. Prior to spending the $$ for a rebuilt distributor, I have a call in to a tranny guy. I think I'll do the AC volt test for the vss, wheels off ground in gear.
Thanks for the comment.
Steve
Old 03-11-2008, 07:46 PM   #8
keithr0005005's Avatar
i bet its the brake switch....any engine sensor....such as the ones in your dist....will throw a code
Old 03-11-2008, 08:01 PM   #9
I'll be sure to get to the brake switch in the AM. Of course I looked at it the other day and its a real dream job to work on. I'll put a spring load to hold it up with rubber cord and take 'er for a hwy spin.
Thanks, Keithr
O'Steve
Old 03-27-2008, 08:09 PM   #10
Well, I checked brake switch operation and connection and it seemed to be operating just fine. Several days later everything went back to normal. Cruise and overdrive work perfect. Was it a bad conn. at the brake switch, VSS, dumb driver? I haven't a clue but if ever it acts up again and I figure it out I'll be sure to give you all a shout. Now tomorrow's another day.
Thanks a million for the help.
Steve Foley, Plymouth, MA
overdrive prblems? ksbs2007 Ford Truck Forum 2 03-02-2008 12:53 PM
b2200 jumps into overdrive mazdatrucker Mazda Truck Forum 0 12-29-2007 12:36 PM
TH 700 Overdrive lockout 1984heartbeat Chevy Truck Forum 7 09-13-2007 08:53 AM
Engine and overdrive light chief Ford Truck Forum 2 03-30-2006 07:27 PM
should I use overdrive? all4fun222 GMC Truck Forum 10 12-17-2005 07:40 PM
