| Rear Defroster problems Hi there, just a newbie here at the forums page. We have a 1999 Jimmy and the rear defroster doesn't seem to be working. Any suggestions from the members. thanks |
| look at the grid closely for any breaks in the grids/lines across the glass. does the switch led light up when on? |
| Yes the light comes on when. I couldn't see ant breaks in the wires. |
| Welcome: There is a wiring harness, looks like a little plug, that connects the defroster. I believe it is located in the upper corners of the glass. On both sides. Sometimes with the flip open glass like these, they come loose, make sure the flat metal connections are free from corosion and that they are firmly attatched. If that does not remedy the problem here, double check the fuse, make sure it is not blown. Those defrost units drain a lot of jucie, and if the heat, wipers, headlights and defroster are on, sometimes it can skip enough in the power supply to trip the fuse. I would start there, and then post back an see if that helps.
| Thanks for the input I will check your suggestions in the morning.
__________________ 1999 GMC Jimmy 4x4 4.3L Vortec V6 Wifes truck I drive a Saturn 1999 Saturn SL1 1.9L |
| rear end | 86 chev guy | GMC Truck Forum | 9 | 12-15-2007 05:46 PM |
| rear end sag | bcookn | Toyota Truck Forum | 4 | 02-12-2007 11:00 PM |
| Interior Problems...Seat Memory buttons & Rear Does not unlock ... | dlshunter | Chevy Truck Forum | 2 | 01-03-2007 08:54 PM |
| rear end | 87sierraclassic | GMC Truck Forum | 12 | 09-21-2006 11:13 PM |
| The vehicle, an lder sedan, slid under the rear of the truck and was crushed as far back as the rear (Chico Enterprise-Record) | trucknews | Truck News (headlines) | 0 | 09-30-2005 12:30 AM |
