Old 04-02-2008, 07:59 PM   #1
doc87's Avatar
doc87 is on a distinguished road
2007 GMC Sierra traction control
is there an option for 2wd sierras to turn the traction control/stabilitrak on and off?
doc87 is offline   Reply With Quote
Old 04-02-2008, 08:10 PM   #2
junior3382's Avatar
I am unsure about this question..... why would you want traction control off? Much less, I did not know they even had traction control..... only on the 2wd's?
Old 04-02-2008, 08:15 PM   #3
doc87's Avatar
i can't spin tires and there is a lot of lag during take off on my truck. i know that the 4x4 trucks have this option but i am unsure if the 2wds do.
Old 04-02-2008, 08:26 PM   #4
o3shortbed's Avatar
try pressing the button adn holt it for 5 or 10 seconds that might turn it off. it does in a new trailblazer
1998 Jeep Grand Cherokee Limited 5.2 Full time 4WD NP249
Old 04-02-2008, 08:47 PM   #5
doc87's Avatar
my truck does not have the button but does have the stabilitrak
Old 04-02-2008, 08:49 PM   #6
junior3382's Avatar
If there is a traction control system, there should be a button. o3shortbed, where is your button? that might help him look for it.
Old 04-02-2008, 11:02 PM   #7
doc87's Avatar
on the 4x4 it is under the climate controls, there is just a cubby hole there on mine.
Old 04-02-2008, 11:49 PM   #8
junior3382's Avatar
Then perhaps either you cannot shut it off, or it is not there. Listen to my reasoning. I sell new cars for a living. Primarily Suzuki's, however, we do sell Toyotas and Scions. I can sell Chevys, but rarely do. The chevy dealership is on the otherside of the city. I can check with them tomorrow. However, here is where I am going with this. Almost every model we sell has either an eletronic stability control, or a traction control system. However, only a handfull have a button to shut the system off. Most of them however, it is always there, and working on its own. If your truck does have it, you may not be able to shut it off, however, there is also the possibility you do not have it. Like I mentioned, I will call up to chevy tomorrow and double check this, however, does this make sense? I mean perhaps someone else here knows this.... but till then, I will see what I can find out for ya bud.
Old 04-03-2008, 06:04 AM   #9
doc87's Avatar
ok, thank you. whenever i start to slip a tire there is a traction control light that does come on in the gauge cluster. Since i do not have the button is there a possibility that i could have one installed into my truck?
Old 04-03-2008, 06:50 PM   #10
crabtruck's Avatar
Are you looking to do this so you can peel out ?
Seems like lag would not be Stability related.
A button could probably be wired to simulate being in 4wd
but that would effect other things as well I'd guess.
Usually these are closely wired to the ABS system.
By the way "Traction Control" is a marketing name only
and is used by BMW, Cadillac, Lexus, Mitsubishi, and Volvo.
GM uses the name StabiliTrak. Same difference.
2007 sierra 1500, hard to turn wheel at first gt2003 GMC Truck Forum 3 06-28-2008 10:27 AM
2007 Sierra Grease Fittings GH05 GMC Truck Forum 1 03-16-2008 10:46 AM
Exterior cab visors for 2007 Sierra classic outlawkyote GMC Truck Forum 0 11-17-2007 08:37 PM
Question about my 2007 GMC Sierra (New Style) moistmaster GMC Truck Forum 6 10-26-2007 09:11 PM
2007 GMC Sierra Classic Crew Cab Head Rests Removal TX900s GMC Truck Forum 1 08-02-2007 10:56 AM
