| Junior Member Join Date: Apr 2008 Location: Iowa
| Fuel Pump Hey Guys, I'm looking to clean the injectors for 2007 Denali 1500, LQ9, for the first time. Have a 3M fuel injection cleaning setup and 3M solvent. First anyone have a suggestion for deactivating the fuel pump? Once deactivated, what'st the best way to bleed the pressure off of the system? Finally, are special tools necessary for disconnecting the fuel inlet and return lines from the rails? Thanks! Rick |
| Senior Member Join Date: Mar 2008 Location: levittown pa
| isnt it just the one that you plug into your brake booster vaccum. if it is you shouldnt need to do anything otnher then unplug the vacuum line and walla. if its not you do need special tools to get the lines diconnected and you could probley jump pull the fuse for the fuel pump but im just kinda guessing on it. you might want to find the owners manual for the 3m cleaner. |
| 87c10slammer is right.. it goes into you vaccum lines. on your 07 i dont know witch one. you have to have it running to use that 3m cleaner.
| Fuel Pump Thanks for the help guys! |
| Fuel pump, fuel tank, filler neck, filter... | lassy | GMC Truck Forum | 6 | 04-11-2007 06:48 AM |
| Fuel Pump | SBHoney | Chevy Truck Forum | 4 | 03-15-2007 10:10 AM |
| another fuel pump | scvpiper | Chevy Truck Forum | 4 | 03-08-2007 11:41 AM |
| fuel pump | scvpiper | GMC Truck Forum | 2 | 03-05-2007 08:51 AM |
| Fuel pump.. | mslwpk | Ford Truck Forum | 7 | 04-06-2006 06:39 AM |
