Old 04-14-2008, 05:53 PM   #1
oakhill is on a distinguished road
hub assembly replacement
My GMC dealer told me I needed new hub/wheel bearing assemblies on the front of my 99 GMC pickup and rather than pay an enormous amount of labor, I want to replace them myself. Can anyone tell me a step-by-step method for removing old and installing new hub/wheel bearing assemblies on a 99 GMC Sierra, 4WD, ext cab, new style pickup? Thanks in advance.
oakhill is offline   Reply With Quote
Old 04-15-2008, 06:33 AM   #2
remove tire
remove caliper and pads
remove rotor
disconnect ABS wire
remove CV axle nut (31MM?)
remove the 3 bolts holding hub on the spindle (15mm or 13mm??)
tap hub with a hammer to break it free and install new hub.
make sure you tourqe the CV nut down to spec, i think it's around 180 ft/lbs
Old 04-15-2008, 06:38 AM   #3
i'll do a step by step with pictures if you need them, i have a '97, but it should be the same.
i think it took me less than a half hour to replace my passenger side with an impact gun.
Old 04-15-2008, 10:16 AM   #4
thanks for your help. i know i can do it, but i keep hearing that i should not let the caliper hang down by the tubing because it will have an effect on how well the brakes will work? if you have the pictures available, i know they would help. again, thanks.
Old 04-15-2008, 02:03 PM   #5
get a coat hanger to hang the caliper from the shock or something.
Hub Assembly problem matt2500HD GMC Truck Forum 1 03-30-2008 03:46 PM
wiper assembly 98 silverado denh2000 Chevy Truck Forum 2 02-09-2008 06:17 PM
Rear vacuum assembly linkage joesup Chevy Truck Forum 5 11-28-2007 06:01 AM
Brake Light Switch Assembly jessevargas Chevy Truck Forum 2 09-28-2007 03:09 PM
fuel filler assembly jestructure Chevy Truck Forum 7 02-09-2007 06:25 AM
