| front diff question I have a 1995 1/2 ton sierra with a 14 bolt rear. My question is does any one know what size ring gear the front would be if not is there a id tag on it some where? |
| you have a 1/2 ton with a 14 bolt?
| If everything is factory, the ID tag in the glove box should have the code. And replacing what you need finding the right part by vehicle is easy at a local repair store too. Just a thought.
| look on the housing there should be a medal tag on the top somewhere
| Regardless of the rear axle (probably a SF c clip 14 bolt anyway) the 1/2 ton truck with 6 lugs only used a 8.25" ring gear up front. This front diff was the only one available. Where are my manners? Welcome to the site......... |
| Thank You. Sf Im Guessing A Semi Floating. |
| Yes sir, SF stands for semi floating. This means that the axle shaft provides most of the support for the rear. This is a flanged axle, and the wheel lug nuts bolt directly to the axle shaft. This axle, while strong, is not quite the same as the other Full floating designs. |
| front diff | 98k1500 | Chevy Truck Forum | 5 | 02-29-2008 03:04 AM |
| front diff gears 99 1500 sierra 3.73 to 4.56 | ddraszt | GMC Truck Forum | 1 | 06-16-2007 11:59 PM |
| what size diff cover for front end | CJCJ | Dodge Truck Forum | 0 | 07-11-2006 05:00 PM |
| front question | f-250 | Ford Truck Forum | 15 | 03-30-2006 07:25 PM |
| front end question | dunner1 | Chevy Truck Forum | 2 | 12-12-2005 12:05 PM |
