Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: 89 GMC Suburban shaking at 45 mph and 65 mph
    Jun 2008
    20
    Unhappy 89 GMC Suburban shaking at 45 mph and 65 mph
    Hey guys, new here. Just picked up an 89 Suburban and noticed a significant shake at 45 mph that goes away at around 50 mph and comes back at 65 mph and goes away again at 70 mph. Haven't had it any faster than that. Any ideas? It seems the whole truck shakes when it does it.
    Jeremy Stillson
    '89 GMC Suburban
    Jun 2008
    3
    could just be tires,or stableizer shock
    Jun 2008
    20
    I'm leaning towards the shocks because I can see some cupping on the front tires, but I have never experienced that kind of shake because of shocks before. I have also never owned an SUV. I am also not sure how old the tires are, but may replace them when I'm able to. We'll see. In the meantime, keep the suggestions coming.
    Jeremy Stillson
    '89 GMC Suburban
    Mar 2008
    N.Y.
    10,792
    Blog Entries
    1
    balance and rotate the tires, check air pressure to 75% of max. assuming its 4x4 the cupping shows up if the caster/camber is off
    Jun 2008
    20
    Quote Originally Posted by leolkfrm View Post
    Not 4x4. It is 2WD.
    Jeremy Stillson
    '89 GMC Suburban
    Senior Member ukrkoz's Avatar
    Feb 2008
    174
    recurrant shake at various speeds is the first sign of unbalanced tires. if balancing did not fix it, check hub bearings, most likely going bad. shocks won't do this.
  7. #7
    Jun 2008
    20
    I'm thinking tires now. I noticed the driver rear has some movement to it. I followed behing the truck in my wifes car and it's hard to describe but the tire isn't true. Passenger rear seems to be ok, but I think I will replace both. Hopefully it will fix the problem.
    Jeremy Stillson
    '89 GMC Suburban
  8. #8
    Jun 2008
    33
    look for a busted belt.Same thing was going on with my wifes Rodeo.It would shimmy at about 25 then at about 60.The rear driverside had a busted belt under the tread.Is there any pull to the right or left.Maybe alignment or ballance.I don't think its the shocks.You should hear it if its the wheel berrings.
  9. #9
    Jun 2008
    20
    It doesn't seem to pull either way, so hopefully the tires will fix it.
    Jeremy Stillson
    '89 GMC Suburban
  10. #10
    Mar 2008
    N.Y.
    10,792
    Blog Entries
    1
    if you over inflate the tires about 15lbs over max and it goes away its usually a belt shift. Do it to test only don't leave them over inflated
  1. Shaking Front End
    By ukrkoz in forum GMC Truck Forum
    Last Post: 05-18-2008, 04:17 AM
  2. 06 dually shaking
    By plowboy9400 in forum Dodge Truck Forum
    Last Post: 02-13-2008, 05:17 PM
  3. shaking
    By shagn84408 in forum Dodge Truck Forum
    Last Post: 02-01-2007, 06:21 AM
  4. Shaking...
    By 1bj in forum Nissan Truck Forum
    Last Post: 11-29-2006, 11:09 AM
  5. bad shaking when driving
    By 98Z71 in forum Chevy Truck Forum
    Last Post: 10-26-2005, 08:20 PM
