Old 06-15-2008, 05:44 PM   #1 (permalink)
scavanger is on a distinguished road
rear axles
A while back I had to do some brake work on the back of my 1/2 ton 95 extended cab shortbox Z71.I noticed that I could move the axles up and down slightly.There is no seal leakage. Is this normal or is it axle wear and if so how long will it be before this will cause a problem. The truck has 228k on it.
Scav.
Old 06-15-2008, 06:31 PM   #2 (permalink)
MORROWMUDDER's Avatar
MORROWMUDDER will become famous soon enoughMORROWMUDDER will become famous soon enough
you have up and down movement and not in and out movement correct? with that many miles it would be a good idea to replace the bearings any way if you have not already did at some point. how often have you changed your gear lube? ever notice metal flakes or shiney milky streaks in it? good idea to inspect the lube, it gives ya a good indication on how much wear you are getting. does your diff cover have a magnet on it? those are the best kind to have. but as for the up and down no thats not really a good thing. in and out is pretty normal given a small fraction of an inch that is.
MORROWMUDDER is offline   Reply With Quote
Old 06-15-2008, 07:50 PM   #3 (permalink)
yep , up and down , it isn't a lot but enough that I can feel it. I have only had the truck for about 10,000 miles and am planning on changing all the gear boxes and the auto trans in the next couple months. I will be sure to check for filings when I do that.Not driving it a lot right now. I need to replace the clutch in my vette before I start on the truck.
Thanks for the reply
Scav.
Old 06-15-2008, 08:36 PM   #4 (permalink)
stumpuller454's Avatar
stumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to behold
a little play isn`t horible, in ad out is normal too, there is always movement in the c-clips in the differential. but if your giving the truck a once over bearings are cheap, and its not a bad job really.
stumpuller454 is online now   Reply With Quote
Old 06-16-2008, 06:22 PM   #5 (permalink)
ponie1992 is on a distinguished road
I would also suggest changing out the axle bearings. They are usually not too bad to change.
Jeremy Stillson
'89 GMC Suburban
ponie1992 is offline   Reply With Quote
Old 06-16-2008, 08:43 PM   #6 (permalink)
What concerns me is there are no inner races. The bearings ride on the axle. Wouldn't new bearings be a waste with out new axles ? I am thinking it might actually be the axles that are worn rather then the bearings .
Scav.
Old 06-17-2008, 08:44 AM   #7 (permalink)
mantis is on a distinguished road
Scav.
Unless you plan on keeping it a really long time I wouldn't worry about it.Unless you notice it when you are driving or if there is ware on the tires.I think you should be fine.as long as there is not significant play
mantis is offline   Reply With Quote
Old 06-19-2008, 04:12 AM   #8 (permalink)
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
when/if you pull it apart and if the axles are worn, replace the axle bearings with worn axle repair bearings, they are sealed axle bearings complete with seals that ride on the axle shaft farther out so you don't have to buy new axles, all parts stores carry them, also use synthetic lube.
jimbo543 is offline   Reply With Quote
Old 06-19-2008, 04:41 AM   #9 (permalink)
+1.........
Jeremy Stillson
'89 GMC Suburban
Old 06-29-2008, 07:59 PM   #10 (permalink)
thanks a bunch I didn't know they had those. The synthetic will be going in both differentials before cold weather hits .
Scav.
Ranger locks axles... 94Ranger4x4 Ford Truck Forum 3 03-29-2008 04:36 PM
need advice on axles - cv boots cathunter Chevy Truck Forum 3 12-02-2007 07:43 PM
Axles Deltasigcj5 Chevy Truck Forum 2 05-14-2007 07:24 PM
4wd axles bigowe Ford Truck Forum 0 04-28-2005 03:08 AM
Dana Corporation Providing Axles and Driveshafts for General Motors 4x4 Medium-Duty Trucks (The Auto Channel) trucknews Truck News (headlines) 0 11-10-2004 12:30 AM
