Hey guys.I am having a problem with my '99 sierra 1500 4.8LT.It started last summer.I cleaned the ground to the frame and it ran great for about 6 months or so,Then acted up again.Cleaned the ground again and it ran fine for a little while.Pulled out of the driveway and it stalled out.Pushed it back in the driveway and tried it again and nothing.About 5 hrs later I tried it again and it started right up. I tried it again in the morning and it started up.So I did a pressure test it read about 50 PSI. It was running fine and than started to loose pressure,droped to about 10 PSI and stalled out. after about another 5 hrs I tried it again and it ran for about 6 minutes and then lost pressur again. Switched relays no differance.Would this be some kind of vapor lock? I took the gas cap off and it still acts the same.I am getting power to the pump but nothing.If I go direct to the pump it will start
.thats where I am now, and I don't have much hair left to pull out
