| | #51 |
| are you talking about the center bolt that has the 2 pieces of metal that flap like wings?? should be able to put a backup on it. why are you taking this piece off or did i miss part of the conversation?? |
| | #52 |
| you need to drill that metal piece in the middle out. that's what's causing your tailgate from working, it's seized up.put it in a bench vice and use a bit about the same size as that rivet. you shouldn't have to go very deep before the face of the rivet breaks off, then you can replace it with a bolt and a nylock nut. it may be easier to drill out the rivet from the back side. i think the back side of the rivet has a lip that is easier to drill.
| | #53 |
| Senior Member Join Date: Dec 2006 Location: Illinois
| yuh the wing thing
__________________ Ashley My first truck was a 1988 Chevy 1500 with the 305 My new truck is a 1997 GMC 1500 with the 350 |
| | #54 |
| ahh jeez you said this was going to be easy, where can I can a new rivet like that? napa?
| | #55 |
| the ones i have redone had a bolt. they would get tight and have to use a backup wrench on it to break it. evidently if they come riveted, i been fixing everyone elses stuff once they got through with it. |
| | #56 |
| it is easy. just drill the rivet out and replace with a bolt and nylock nut. ![]() you could try some PB blaster if you want to keep from tearing it apart, but i don't think it will work.
| | #57 | |
__________________ member map add yourself | |
| | #58 |
| believe me, im not making fun of your fix. i think it works better too. |
| | #59 |
| I did it! Its fixed
| | #60 |
| congrats on the fix!! are you starting to like the truck more now?
| Tags |
| chevy tailgate, tailgate |
