Old 06-27-2008, 08:40 PM   #1 (permalink)
aeroned is on a distinguished road
Can't turn ign key on 96 1500
Hi everyone, just signed up and need your help with my 96 1500.
All of the sudden, I can't turn the ignition key, it was working just fine. I tried some lube, wiggling the trans arm, all the simple 'fixes' but still no luck.
I disassembled most of the column. In the process of removing the ignition switch, I busted the tang on the "differential" part of the key assembly (I'm going to have to get a new/used replacement for that). With the switch removed, the key still doesn't turn.
So any ideas on what might be jamming the key/tumbler preventing it from turning? Also any ideas where I can get the new key assembly?
Thanks,
Ned
aeroned is offline   Reply With Quote
Old 06-27-2008, 09:54 PM   #2 (permalink)
gmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to behold
Welcome to start which. Follow the steel rod on steering column that goes from switch to this part where a lot of wires go plugged into to me that's whats wrong when you by one they come with instuctions on how to replace. Hope this helps! GMC
PS-You might have to remove lower panel under steering wheel to see what im talking about you can't miss the connector with a lot of wires going into it now there is a certain way of putting it back you might have another connector that besides it match them together so you won't have problems getting them into new switch.
I hope you understood what I mean.
Old 06-28-2008, 05:27 AM   #3 (permalink)
Ned did it work was that it?
Old 06-28-2008, 07:13 PM   #4 (permalink)
Moderator
Those lock cylinders were really bad about wearing out and not wanting to turn.
Old 06-28-2008, 08:30 PM   #5 (permalink)
Thanks for the ideas!
Leave it to John Wayne, always the hero and a Ford owner to boot!
The tumbler cover came loose and a spring got caught under it preventing the tumbler from turning. Somehow I got the key to turn and removed the tumbler. Easy fix after a visit to the FLAPS.
Now I still need to get the plastic piece that goes into the ignition switch from the key assembly. I might try the dealer or try to glue the finger back on.
Ned
Old 06-29-2008, 07:21 AM   #6 (permalink)
Way to go MrJohnWayne (DUKE) next time it will be what I said. LOL
2007 sierra 1500, hard to turn wheel at first gt2003 GMC Truck Forum 3 06-28-2008 09:27 AM
1995 K 1500 Cheyenne Key will not turn larbec7 Chevy Truck Forum 11 05-16-2008 07:31 PM
GMC van won't turn right 340doc Chevy Truck Forum 6 02-27-2008 05:26 PM
Turn Signals out HELP! bulachip GMC Truck Forum 16 08-17-2007 01:45 PM
they had their turn... peterbilt Ford Truck Forum 21 07-12-2007 03:26 PM
