GMC Truck Forum - GMC truck talk, etc. |
#1 (permalink) |
torsion key questions
i have a stock 2005 sierra z71...will the stock torsion keys adjust to lift the front end or do i HAVE to buy new keys??
also will i have to get a front end alignment after the "lift"?? how do i go about doing such lift?? |
#2 (permalink) |
yeah you can get about 1 1/2 inch lift by adjusting them but not how you want to lift your truck. if i had your truck i would go out and get a 6 inch sysp. lift and call it done with 33's or 35's. but if you adjust those torsion keys only you will be replacing bearings and knuckes and putting you axles in a bind. wearing out all your parts really fast.
#3 (permalink) |
Moderator
they make leveling kits for your application. like chevy said, it would not be wise to mess around with your torsion keys as this affects vertical travel. yes, you will need an alignment after adjusting the front end.
#4 (permalink) |
Anytime you make a performance adjustment to the front end of an IFS systems, you will need to take it in immediately for an allignment. Make sure you let them know what you did and why, so that they do not simply reverse it to adjust the allignment.
Lets get some mud on the tires...eh?!?!? ![]() ![]() ![]() OWN: 1998 Chevy Blazer ls 4x4 4.3l Vortec V6 1998 Mazda B3000 SE 4WD 3.0L V6 3" lift ![]() 31x10.50 Liberator A/T's |
| Torsion Bar Help | waterloo88chev | Chevy Truck Forum | 9 | 01-26-2008 08:48 AM |
| Torsion Bar | peba | Chevy Truck Forum | 6 | 10-11-2007 02:16 PM |
| torsion bar | duckkiller0010 | Chevy Truck Forum | 10 | 09-11-2007 01:35 AM |
| Torsion Bar adjustment? | JohnD | Chevy Truck Forum | 4 | 01-31-2007 10:20 AM |
| S10 4x4 Torsion Bar Removal | matthews | Chevy Truck Forum | 1 | 08-02-2005 10:37 AM |
