Old 07-21-2008, 09:50 AM   #1
kandyman is on a distinguished road
1998 gmc truck
ive got a 98 gmc with a 383 vortec in it. I have a problem where it wants to cut out when you get on it. It is fuel injected with 1.6 rockers, lt4 hot cam, cai and some other parts. If I easy into it I can get it to go clear past 5 grand but when you punch it it cuts out at 4 grand. It acts like its starving for fuel but the fuel pressure says its alright. I dont know if the fuel regulator is adjustable or not is it.
kandyman is offline   Reply With Quote
Old 07-21-2008, 11:56 AM   #2
how hot of cam?? what pistons are you using and what grade gas are you using?? have you changed your ignition system or still using stock??
Old 07-21-2008, 12:24 PM   #3
still stock ignition but I have read up on this and there are plenty of people that have 383 with stock ignition. with 1.6 ration rockers the cam is .525/.525 which there again plenty of people run this cam. I use only premium 91 octane. I am running keith black pistons.
Old 07-21-2008, 03:09 PM   #4
when did you start with this problem?? how long after the buildup i mean?? does she spit and sputter at 4 grand?? hard to diagnose with the little info that i have but it might have an air problem. if she cant get enough air when gassin her, she will try to pass out and stall. have you replaced the stock breather with something that is going to breathe better?? might be why you can ease off into her and not be able to push the envelope.
Old 07-22-2008, 03:22 AM   #5
I havent got it to run good enough to put it on the road yet, so the build isnt over yet. I have a huge cold air intake that moves plenty of air. When it hits 4 grand it cuts out and tries to die on me.
Old 07-22-2008, 06:46 AM   #6
have you pulled the plugs to see if they are fouling out?? also, have you reprogrammed your ecm to allow for the increased displacement and fuel air ratio??
Old 07-22-2008, 10:22 AM   #7
sry, yes it was tuned by wheatlet tuning outta texas, the plugs look fine they show just a little brown or tan on the ceramic parts of the plug. I dont know what to do.
Old 07-22-2008, 02:56 PM   #8
wish i could tell you something good to look for. i have been thinkin about this half the day and cant come up with anything besides that you might have 2 new parts that are conflicting with each other. sorry that i cant be anymore help. hopefully, someone here will chime in with an idea. sneakysportsman is pretty good with engine performance but havent seen him in a while.
Old 07-22-2008, 05:19 PM   #9
stumpuller454's Avatar
if you can road test with a buddy and a fuel pressure tester that is visable, check the pressure at the 1-2 and 2-3 shifts at W.O.T must make 52 psi minimum, i`ve heard of alot of guys removing the regulator (on 383s) or by-passing it to get full pressure, not sure how "okay" that is...
Old 07-22-2008, 07:04 PM   #10
is there a way to adjust the regulator.
1998 chevy truck wmpk1762 Chevy Truck Forum 12 05-17-2008 05:30 AM
1998 Chevy Z71 sophiesride Chevy Truck Forum 1 03-25-2008 07:33 AM
1998 gmc 1500 4 x4 gravyk Chevy Truck Forum 9 01-08-2008 07:04 PM
1998 chevy truck fuel pump regulator swflatt Chevy Truck Forum 2 01-04-2008 07:29 PM
1998 chevy z71 truck hayeshumpy1 Chevy Truck Forum 2 11-26-2007 07:35 AM
