| Full Member Join Date: Oct 2007 Location: Hustisford, WI
| water leak After driving 60 miles and parking, I notice a puddle of water under the truck, under the radiator overflow container. It is clear liquid and not from the radiator or the overflow. The level in the radiator is normal. Also, I wasn't running the AC. Any ideas?? Thanks |
| windshield washer fluid? If you are running just water anyways......
| most likely condensate from expension canister. even if you do not run a/c, canister is very cold and has tendency to collect humidity on it. check all fluid levels, and if everythings checks out fine - just let it be. you see, now you know why they make all those colors for all those fluids, he-he. |
| | #4 | |
| Senior Member Join Date: Dec 2007 Location: Alberta
yeah depending on the vehicle the compressor runs intermittantley....making for some condensation
__________________ 1998 GMC K2500 Ext.cab short box 454ci 1951 Chevrolet 1420 pickup like new! Red seal certified Journeyman Automotive Mechanic | |
| | #5 | |
| Water leak. Quote:
| Did you happen to have the controls on defrost? The air condioner will run when set on defrost. This is done so everything in the system is kept lubricated when not being used. |
| Thanks for the replies. I do have the defrost on, set all the way to the left, no heat. I'll keep an eye on it. |
| | #8 | |
to defrost or to "windows or windows/floor"? defrost turns heating element on(and is a seperate button on the dash. won't do much if blower is not turned on. confusingly enough, logos are the same for either. a/c simply hastens moisture removal from the cabin air/windows. but yes, a/c needs to be run once a month for short time to prevent clogging. | |
| Senior Member Join Date: Jul 2008
| If your defrost is ON, that is definatly your issue. As said above its for lubrication purposes, but so that your compressor runs some in the winter months and not to seize for non use, and you WILL be using your defroster, the defroster will turn on the AC compressor. Normal in all cars manufactured for quite some time now that I am aware of. I am a bit suprised though, if your defrost was on, and you have it set to NO heat on the cool setting, you did not get a little fog on windshield too. |
| water leak in floor board | watkins7871 | Dodge Truck Forum | 3 | 07-04-2008 07:58 PM |
| water leak | rednekracer | Chevy Truck Forum | 35 | 10-29-2007 10:05 AM |
| another water leak question | tims84k10 | Chevy Truck Forum | 2 | 10-19-2007 04:19 AM |
| 2007 Chevy A/C = water leak. | Surf'n'Turf | Chevy Truck Forum | 1 | 06-04-2007 11:24 AM |
| water leak | vincent tomaro | Chevy Truck Forum | 4 | 04-16-2007 07:21 PM |
