Old 08-04-2008, 12:32 PM   #1
lost in wyoming is on a distinguished road
92 a/c problems
I have a problem with my a/c. The clutch will engage and then engage again. It repeats this but will not stay engaged. Can I just replace the clutch or does the whole compressor need replaced?
lost in wyoming is offline   Reply With Quote
Old 08-04-2008, 05:35 PM   #2
leolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud of
welcome.yes you can replace just the clutch but make sure its the problem. Sounds like it needs a shot of freon
Old 08-04-2008, 08:10 PM   #3
checked that its okay
Old 08-05-2008, 06:34 AM   #4
check the wire from the pressure switch from the dryer sometimes they break connection and keep cycling the clutch
Old 08-05-2008, 07:26 AM   #5
gmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to behold
I agree check sight glass for bubbles first, or place gauges on it to know for sure.
Be good! GMC
Old 08-05-2008, 07:44 AM   #6
Thanks guys.if i put a test light on the pos side at the compressor it has power.every time the clutch kicks out the test light gos out. if i pull the wires off it wont lose power.I will chech the presure switch todaythank you
Old 08-05-2008, 08:00 AM   #7
If i put the test light on the wires on the compressor it losses power every time the clutch kicks out if i remove the wirers the power stays on. I wwill check the pressure switch today .thank you
Old 08-05-2008, 09:03 AM   #8
Hello again if I put a jump wire across the presure switch the air works great. tells me the switch is bad can that be changed with out draining the hole unit thanks again Lost
Old 08-05-2008, 10:36 AM   #9
Yes there is a schrader valve inside where it screws on. just spin it off and spin the new one on, freon loss is no more then taking the guages off
Old 08-06-2008, 03:21 PM   #10
Ok here it is dont buy cheap gauges from walmart. got a good gauge filled with 134 and it cool great. thank for all the help
4WD Problems please help! deere9670 GMC Truck Forum 7 04-30-2008 04:16 PM
7.4l(454) Problems ryeja Chevy Truck Forum 40 02-21-2008 08:28 PM
03-06 6.0L problems USAFGuy Ford Truck Forum 4 04-05-2007 04:43 PM
Guy Problems Dakotah Off-Topic 25 04-22-2006 09:58 AM
ABS problems S pump Chevy Truck Forum 5 03-08-2006 01:31 PM
