Old 08-04-2008, 06:37 PM   #1
vdaily89 is on a distinguished road
95 Sierra rear brake line
The metal line on the rear drivers side of my truck has rusted & has a hole in it. It is the one that runs along the frame rail. Any tips on changing it out? I've never flared a line before, but I don't want to pay a shop either. I know they will be expensive.
Thanks in advance
vdaily89 is offline   Reply With Quote
Old 08-04-2008, 08:22 PM   #2
flaring a line is not very hard but it does take practice. i would suggest you buy some extra line to practice on (make sure you make them a double flare or it will leak). you may be lucky and be able to buy a whole section, so all you need to do is undo the fittings and reconnect.
either way make sure you cut back to a good section of line and not just the little bit that is leaking.
i'd rather be hunting
Old 08-05-2008, 06:46 AM   #3
Welcome to the forum
As mudseeker says a little practice and you can do it! If you are going to tackle it I would recommend changing the complete line to both rear, and check the front, probably getting bad. They make a soft brake line similar to soft copper that makes bending much easier, but a little more money. Last quote I seen was 125 per wheel for line replacement. If you do it yourself flush the line with fresh fluid while you are at it.
Old 08-05-2008, 09:56 AM   #4
GMC1993Sierra will become famous soon enough
+1
I replaced all of mine from the front when I replaced my gas tank. I think it's kind of tight if the tank is still in place but not sure on the 95 trucks. I didn't flare any of the lines - I found lines that were different sizes and planned it out so they all fit. One line was too long and I just put an extra bend in it in the shape of a "U" so it would fit. The brake lines were pretty rusty behind the gas tank and the fuel lines also started to rust so I replaced those as well.
Personally I'd avoid flaring the lines if you can avoid it but that's my personal preference.
1993 GMC Sierra (RIP)
186k miles - She'll be missed. But loving the 2009.
GMC1993Sierra is offline   Reply With Quote
Old 08-05-2008, 11:10 AM   #5
Thanks guys. I'm going to replace the entire piece from fitting to fitting. It's only about 3 feet. I'll see if I can find the soft line.
Tags
brake lines, brakes, flareing
Dual brake reservoir, rear section is for rear brakes? K1500_Dude Chevy Truck Forum 11 04-09-2008 11:10 AM
E-brake rear cable teemsta Chevy Truck Forum 5 03-28-2008 01:20 PM
decreasing rear brake 1984heartbeat Chevy Truck Forum 7 09-17-2007 04:15 AM
1990 sierra 2wd ext cab rear end or brake howl????? qwerty123 GMC Truck Forum 6 10-12-2006 09:44 PM
Chevy disc brake rear end 75K30 Truck Classifieds 5 08-17-2006 06:21 PM
