Old 08-06-2008, 07:58 AM   #1
lost in wyoming is on a distinguished road
truck wont start. bad cat?
Ok here it is Iam helping a freind with his 97 gmc it brings up a low flow code an the cat #2 bank. ran real bad now wont start at all. will one bad cat couse it not to start? it has two
lost in wyoming is offline   Reply With Quote
Old 08-07-2008, 10:52 AM   #2
z07
z07's Avatar
z07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of light
A typical cat failure affects performance at the upper end of the power band first not idle and not starting. A strong sulfer exhaust smell, bogging down under load, and stutter under sudden throttle opening are the normal symptoms of a cat that is failing.
To remove the cats from the possible causes of the no start problem, remove (unplug and unbolt) the O2 sensors that are upstream (manifold side) of the cats. The open holes will releave any pressure problem if one exists.
I doubt the cats are causing a no start.
Check the normal things first.
Does the engine turn over at the normal speed when cranking?
Do you have spark at each plug?
Do you have fuel pressure?/Do you hear the fuel pump run when the key moves to run?
Do the injectors pulse?
Do you see any disconnected electrical connectors or vacuum lines?
Will a sample of fuel from the truck run a lawn mower ok?
Does the voltage from the battery drop below 10 volts durring cranking?
Old 08-07-2008, 03:07 PM   #3
we pulled the cats it starts and runs but not very well.the owner drove it last night it quite three times. not pulling any codes. going to check fuil next
Old 08-07-2008, 05:58 PM   #4
leolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud of
Are you using a code reader or a scan tool? sounds like you need to read the sensors and anaylze the results
Old 08-07-2008, 08:49 PM   #5
its a code reader
Old 08-08-2008, 10:26 AM   #6
Moderator
you really should find someone to put it on a scan tool. a sensor could be getting lazy and still not throw a code. i've seen it happen with an IAC valve before. i checked for codes with the scan tool and came up with nothing, but after digging deeper the scan tool finally found the problem.
member map add yourself
truck wont start drewmowles Chevy Truck Forum 50 05-18-2007 02:32 PM
truck wont start when warm redneck Ford Truck Forum 4 04-21-2007 06:16 AM
Truck will start but wont stay running PickUpGirl787 Chevy Truck Forum 6 12-29-2006 11:08 AM
y wont my truck start right away? eganracing Chevy Truck Forum 6 11-25-2006 05:57 PM
Please help... truck died now wont start jarrod Toyota Truck Forum 8 01-31-2005 09:49 PM
