Old 08-10-2008, 08:51 AM   #1
allthrotle's Avatar
allthrotle is on a distinguished road
trans temp gauge
I have a 1999 gmc sierra z71 1500 with 5.3. I was wondering if I could take the gauge cluster out of a 1500hd or 2500 and have a functioning trans temp gauge. Any help would be appreciated
allthrotle is offline   Reply With Quote
Old 08-10-2008, 08:54 AM   #2
stumpuller454's Avatar
way cheaper just to buy a single gauge and a pillar pod, plus you KNOW it will work...
Old 08-10-2008, 10:14 AM   #3
it would be easier to do as stump said, that's how i have mine hooked up.
plus, i don't think the wires are there for the gauge cluster, so you would have to run the wire.
i'd rather be hunting
Old 08-10-2008, 12:33 PM   #4
z07
z07's Avatar
Does your dash display oil temp?
If so go buy an oil temp sender just like the one that operates the gauge on your dash already.
Take it to a plumbing supply store and get a fitting that fits the gauge.
Install the fitting to the oil pan on the tranny.
Wire both the oil temp sensor from the engine and the oil temp sensor from the tranny to a switch that you can mount inside the cab, in the center console for example.
Now when you want to see the oil temp flip the switch to oil when you want to see tranny temp flip the switch to tranny.
Old 08-13-2008, 05:53 PM   #5
allthrotle's Avatar
Thanks for the information guys. I've been looking around on the internet and have found several places thay say the 99 and up trucks are already setup for the trans gauge. I found a web site that sells escalade cluster that they say will bolt in and go to work. I really do appreciate the ideas.
temp gauge Thirdeye Chevy Truck Forum 3 07-23-2008 06:31 AM
Temp Gauge Calibration rdhack Chevy Truck Forum 10 07-22-2008 04:21 PM
Water Temp Gauge 1984heartbeat Chevy Truck Forum 7 09-27-2007 08:05 AM
Non-functioning temp gauge C30 Dooley Chevy Truck Forum 7 03-24-2007 08:31 PM
Temp gauge Help claytonfrnk Chevy Truck Forum 2 03-16-2007 07:20 AM
