| All of the ball joints and control bushings on my front end are flat and cracked. I want to replace them obviously, but should I get the poly ones over the oe replacements?..I don't want to replace them again after this, at least not for a long while. 82,000 Michigan "POT HOLE" road miles. It was like $300+ for the energy suspension master kit Any ideas of where to buy them or where I can get it done? |
| Poly will provide a firm ride, and will give the driver quite a bit of feedback. This means that while the vehicle willl ride with a performance attitude, it will also transfer a few more vibrations and road noise to the cabin. Now you may net be able to determine whether or not a quarter is heads up or not like you would if you ran over the same quarter with a vehicle equiped with solid bushings, or heim joints, but it will transfer more road vibrations. This is good for performance oriented drivers, but for the long hauler, may not be a good idea. Lowest road noises possible are what auto manufacturers are after, and this is why OEM is rubber. Rubber still lasts quite a while. Poly also squeeks more than rubber. |
| Ok thanks...I'm a landscaper, but my truck looks race inspired. Guess I'll be going with the oem rubber...thanx for your input. |
| bushings poly also squeek's quite a bit ar times !!! |
| Tags |
| 1500, 2wd, gmc |
| U-joints | lonestar1128 | Chevy Truck Forum | 12 | 08-28-2008 10:33 AM |
| Need to replace upper & lower ball joints | Space Ace | Chevy Truck Forum | 3 | 05-01-2008 04:49 PM |
| question about ball joints on 98 explorer | 72'CaminoKid | Ford Truck Forum | 3 | 12-13-2007 04:46 PM |
| swaybar bushings | mudseeker | Chevy Truck Forum | 3 | 08-08-2007 01:21 PM |
| f350 ball joints | bristlehead | Ford Truck Forum | 3 | 09-17-2006 12:13 PM |
