| I have a new popping noise as if I have no exhaust on the passenger side of my '03 Sierra 1500. A gm tech guy said it was a bad cat, but it sounds like it is the engine under the air intake tube, near the plugs. Any ideas? I wanted to cut the cats off and straight pipe them, but he said without o2 sensor trick plugs I would have a check engine light on because the rear 2 sensors would say I'm polluting. The magnaflow replacement y-pipe with 2 new cats is like $389. The pipe cutting and replacement is like $45 ![]() |
| compression test to verify there isn`t a bad vavle... also vacuum leaks are common in the intake, use water n soap on intake when running to verify...exhaust sounds like a great idea!
| Warped exhaust manifold?
| It was BOTH of my cats...the insides are loose and blocking the paths...causing backpressure and sluggish driving. Having the straight pipes put on in the morning...thanx guys .. ![]() Any ideas on those trick o2 sensors?...I need 2 rears so I don't drive myself nuts with the check engine light always on. |
| get a CUSTOM ECM tune... they can program them out, plus you get better mileage power and transmission respose, i recommend WESTERS, checkem out online...Kicks the **** outta my old superchips hand held!
| The light never came on, but might ....I will look into it...I have a friend who might be able to hook me up. Here's a link to a quick couple clips of the new sound. Pretty throaty for a 4.3L V6 MySpaceTV Videos: New Pipes by Rick MySpaceTV Videos: New Rumble 40 Series Flowmaster -NO CATS- 4.3L VORTEC V6 by Rick |
| Tags |
| 1500, engine, gmc, noise, truck |
| WTB, Pass. side seat belt | Midnight85 | GMC Truck Forum | 2 | 10-23-2007 08:29 PM |
| WTB Front Pass. Side pwr lock module | PREDATOR | Truck Classifieds | 0 | 08-05-2007 07:47 PM |
| Front door popping noise | cwmoss | Chevy Truck Forum | 2 | 09-10-2006 02:18 PM |
| 97 Mazda engine noise?? | jmmtsu | Mazda Truck Forum | 5 | 08-21-2006 02:55 PM |
| Steering Popping | Rawdeal Phil | GMC Truck Forum | 4 | 01-24-2006 04:21 AM |
