| Junior Member Join Date: Aug 2008
| Stuck valve need help ASAP ok its a 1989 gmc s15 with a 2.5L iron duke in it, yesterday the exhaust valve got stuck open while driving up a big hill, made some horible noises and now is knocking, im guessing it the piston hitting the valve and it stalls and runs like ****. so now the questions: What can cause the exhaust valve to just randomly stick open? the keeper and spring are fine, the valve cannot be moved right now ive tried. i had the valve cover off and exhaust manifold off. and what damages can this cause to the engine if say the valve bent and hit something or what the worst that could of happen? thanks guys |
| damaged piston, cracked head from overheating, damaged cam lobe and lifter............ the engine is going to need a good once over. who knows what else might be broke. |
| ok well that sucks, its definitly not moving i cant budge the thing and i dont wanna try any harder, it never even ran hot while i drove it home, it still runs on the other 3 cylinders. what could of caused it to stick at a high RPM under lots of load, aka hauling stuff for the farm i work at? thanks for the quick reply, and one more tips for trying to free the valve |
| need to remove the head for starters. the high rpm's may have caused your valves to "float". basically your valve springs are weak and could not seat the valve fast enough before the piston smacked it. this guy explains it better than i can. Over reving can cause damage to all engine parts .what is the causes and how it happen and why? - Yahoo! Answers forgot my maners, welcome to the forum Last edited by mudseeker; 08-24-2008 at 09:15 AM. Reason: miswording |
| My buddy just bought a bora scope from snap on this would be a good time to use it. |
| so i almost have the head off. just gotta find the last head bolt, |
| remember you can NOT plane that head if warped it doesn't hold up afterwards
| I need a set of DRW front 4x4 hubs ASAP!!!!!!!!!! | Lonesome7.3 | Truck Classifieds | 7 | 08-01-2008 03:11 AM |
| ERG Valve | Pantharen | Ford Truck Forum | 10 | 05-13-2008 08:07 AM |
| Emergency! Need firing order ASAP!!!! | cporrino | Chevy Truck Forum | 20 | 01-02-2008 11:55 PM |
| science help asap | 72'CaminoKid | Off-Topic | 20 | 11-19-2007 03:33 PM |
| I need help Transmission ASAP | bevansbc | Chevy Truck Forum | 3 | 02-01-2006 08:13 AM |
