Old 08-24-2008, 11:04 AM   #1
Lariat's Avatar
Lariat will become famous soon enoughLariat will become famous soon enough
Unhappy GMC 3500 - starts when it wants & tranny crazy
I have a 1999 GMC 3500 van w/ a 5.7L engine. My truck has been running fine but every now and then, and more so recently, it will start when it wants, cold or hot, and the transmission on one day is fine and another won't drive faster than 30 mph with a crazy speedometer that reads 55-110. I think it's linked for some reason. I replaced the fuel filter and the battery and it seemed to do the trick, but in two days someone borrowed it to go two miles, they got the truck started and it wouldn't go faster than 30 mph and as soon as they stopped and turned off the engine it wouldn't start again. I came to the truck 2-3 hours later and it started right up and ran perfectly.When it decides to run well it sounds perfect. Does anyone have any ideas that might help me?
Lariat is offline   Reply With Quote
Old 08-24-2008, 12:03 PM   #2
Moderator
i had to replace the ignition switch in my '97 truck because the speedo was jumping around to 80 and back while i was going through town. within a few miles, the speedo died and i lost first gear and overdrive.
member map add yourself
Old 08-24-2008, 02:06 PM   #3
leolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud of
put a scan tool on it and evaluate from there
Old 08-24-2008, 04:57 PM   #4
Lariat's Avatar
Thanks Guys,
I was thinking about getting a ProScan Universal and see what comes up. I dried up everything electrical near the engine, MAP Sensor, distributor, etc. Replaced the fuel filter and tested the pump at the same time. I feel it might be the sock in the gas tank.
am i crazy? heavychevy85 Chevy Truck Forum 21 06-28-2008 06:30 AM
crazy larry acservco@sprint Dodge Truck Forum 4 04-16-2008 02:48 PM
Crazy Gauges tdaly GMC Truck Forum 13 09-27-2007 02:00 PM
crazy idle johnmvtv Ford Truck Forum 5 12-26-2006 12:34 PM
going crazy!!!! bronco boy Ford Truck Forum 3 07-06-2006 05:56 AM
