Old 09-02-2008, 06:28 PM   #1
camper95GMC is on a distinguished road
Grinding noise
Hey,
New to the forum, I have a 1995 GMC ex-cab SLT 4x4 with 178,000 miles, no major motor work or transmission work. I have noticed a grinding noise right before it downshifts to first, sounds like the drive shaft u-joint checked it and seems to be ok. Has anyone else experienced this problem. Thanks!!
camper95GMC is offline   Reply With Quote
Old 09-02-2008, 07:52 PM   #2
stumpuller454's Avatar
do you have a manual or automatic trans? (:
Old 09-02-2008, 07:54 PM   #3
junior3382's Avatar
you say a grinding noise, but then mention the u-joint.... is more of a clunking then a grinding? I ask because actual grinding could lead me to think more of a tranny problem, whereas a clunking could be the u-joint, or even the center bearing in the rear axle. Is it only when you down shift? or is it also there when you take off, or use reverse?
Old 09-03-2008, 08:27 AM   #4
Originally Posted by leolkfrm View Post
tranny fluid does not leak thru the slip joint on a driveshaft!
IT CAN cause it did on my darn 80 gmc... noting alot of silicon didn`t fix, there was a pressed in cap in the end of the joint, silly thing eventually started seaping enough to cover the botom of the truck with gear oil!
Although most slip joints are designed in one peice now to eliminate this...
So whats this tranny?
Old 09-03-2008, 05:09 PM   #5
4 speed auto .I Think its a 4L60E. 1Pc drive shaft. It seems like it does it while lugging right before it downshifts. Its not a clunking noise at all. It also does it when pulling out (more so on a hill ) and also backing up. I have changed the tranny fluid and filter and also changed the transfer case fluid and it made no difference whatsoever. I had a S-10 (4sp man) that sounded similar before I would have to downshift.
Old 09-04-2008, 02:28 PM   #6
hmmm have you checked your rear diff fluid? maybe your pinion brgs have gone out and the gears are interacting in an unatural way... would be most noticable during load changes...
grinding noise help tslick Chevy Truck Forum 1 11-14-2007 05:04 PM
1999 s10 zr2 grinding noise, help nordy Chevy Truck Forum 3 11-05-2007 04:35 PM
Grinding Noise? TrucksNBeer GMC Truck Forum 1 12-18-2006 02:01 PM
Grinding noise from transmission 92Jag Chevy Truck Forum 5 12-04-2006 10:14 PM
Grinding noises Big Jim Chevy Truck Forum 2 01-29-2006 10:48 AM
