Old 10-14-2008, 08:50 AM   #1
angelleader's Avatar
angelleader is on a distinguished road
Question Popping out of gear
Hi all. I have a 65 gmc and i seem to be having problems with one of my gears popping out of position. It has a four speed manual, and second keeps popping out of position. The setup for the gears is 1st 0-5mph, 2nd 0-10/15mph?, 3rd 15-25/30mph, 4th 25+. It starts popping out of gear at about 7 mph, but i can quickly pop it back in. at 10 mph it pops out and at that point is too fast to pop it back in without grinding gears and dogs the truck down if i shift it into 3rd. Is there an easy solution to this. A friend said it might be the gear fork, but i thought i would ask around before i go too far.
angelleader is offline   Reply With Quote
Old 10-14-2008, 12:31 PM   #2
cburcham73 has a spectacular aura aboutcburcham73 has a spectacular aura about
i had a car the did that. it would pop out of gear when i would downshift into 2nd. my sync's were shot. that could be your problem.
cburcham73 is offline   Reply With Quote
Old 10-14-2008, 01:20 PM   #3
JOHN JAY will become famous soon enoughJOHN JAY will become famous soon enough
mine would jump out if I was to apply to much torque either in the way of accelerateing or decelerateing to fast. If I held it in gear it was fine though. My solution was to hold it in second.
JOHN JAY is offline   Reply With Quote
Old 10-14-2008, 01:38 PM   #4
03chevy's Avatar
how long has it been sence you replaced the clutch? and have you ever replaced the clutch cable before. and how often do you adjust the clutch? just the 3 questions that we need to help you out more. and welcome to the forum!!
Old 10-14-2008, 03:01 PM   #5
the post about the syncro's is on the right track. is it hard to get in to that gear also? if so, then your brass blocking ring is shot and you will need to replace/rebuild your 1-2 syncro. drain the oil and look for gold colored shavings.
your shift linkage could also need adjusted.
Old 10-14-2008, 05:50 PM   #6
I'm not sure when the last time was that the clutch or any of the trans stuff was touched. I just bought it a few weeks ago from my father in law, but as far as i know it has had minimal maintenance since he rebuilt it and put a 350 in to replace the 305. could it also be too much torque, because I am unsure whether or not they replaced the trans, or kept the same one. I will do more checking.
Old 10-14-2008, 08:15 PM   #7
i doubt torque is your problem. most likely your syncros are bad or you have a shift linkage that needs adjustment. other causes could be input shaft endplay, worn gears or bad bearings.
manual trans are actually fairly simple to rebuild. drain the oil first to see what you are dealing with.
Old 10-15-2008, 03:50 AM   #8
I agree 100% it's the syncro's just replace all while there that way that's it good for a long while also do a re-seal you can do it yourself.
Tags
gear, shifter, transmission
'03 front 4x4 axle binding and popping MADSCOTSMAN GMC Truck Forum 9 03-04-2008 03:56 AM
Popping/binding in front end elkfool Chevy Truck Forum 5 02-04-2008 03:09 AM
Front door popping noise cwmoss Chevy Truck Forum 2 09-10-2006 02:18 PM
02 Silverado Z71 Axle Popping Kevin Hod Chevy Truck Forum 16 04-25-2006 11:17 PM
Steering Popping Rawdeal Phil GMC Truck Forum 4 01-24-2006 04:21 AM
