| Junior Member Join Date: Oct 2008 Location: n.w.ind.
| 1st. post....I have removed the wheel, and caliper the rotor would not budge. I took the axel nut off and using a wheel puller, I managed to push the splined axel thru the rotor. the rotor is still solidly intact, not budging. There are 4 bolts thru the back plate. Do they need to come out? If not, what is holding the rotor on? |
| As far as I know all you should have to do is hit it a couple times with a 3 lbs hammer. Hit it by the studs not on the braking surface! Good luck! |
| I used a 2# hammer. from the back while turning the rotor. didn't help....do the studs stay or come with it? (1 or 2 piece rotor?) |
| The studs stay on the axle shaft. The pressure of the rim holds the rotor on did you try any break away or anything? Are you replacing the rotors? |
| Senior Member Join Date: Jun 2008 Location: kentucky
| Just hit the sumbeach
__________________ MY first truck was a FORD.......I've owned Chevy's ever since. 1995 K2500 4x4 5.7L Cheyenne 1991 T-10 Blazer 4.3L Tahoe Package 2000 Ford Taurus - Spouses |
| Thats what I'm saying! If your gonna replace the rotor then beat the livin **** outta it! lol It's gonna come off one way or another! |
| I was planning on having the rotors turned. I DID SPRAY them with penatrating oil. |
| If thats all thats holding them on -tightness- etc. the I have my work cut out for me..Thank a lot for the info guys.... |
| Yeah there ar eno bolts holding them on! And just a thought isn't it just as expensive to have them turned as it is to buy new ones? Do you have a air hammer you could try to air hammer it off! Or even use a propane torch just to heat it up alittle bit and then beat that thing! |
| is there no threaded hole to run a bolt through to seperate it from the hub assembly?? |
| 1999 dodge diesel 2500 abs light | burton9010 | Dodge Truck Forum | 5 | 08-01-2008 10:29 PM |
| g80 locking diff on 1999 gmc 2500 | tammyolson | GMC Truck Forum | 11 | 03-30-2008 05:50 PM |
| 1998-1999 front end conversion kit? | Mason1998 | Chevy Truck Forum | 7 | 03-10-2008 03:57 PM |
| FS: 1999 GMC 2500 HD 4x4 | bdschumaker | Truck Classifieds | 0 | 01-03-2008 01:02 PM |
| Front axle bearing removal | jandoe | Chevy Truck Forum | 2 | 06-21-2007 10:28 PM |
