Old 11-18-2008, 09:09 PM   #1
huntingup1 is on a distinguished road
Need help with dome light and wiring diagram
Hello, I'm new here. I recently purchased a 95 GMC Z71 with 85,000 original miles on it. Everything is working great except the dome light. I have tried everything I know and haven't been able to solve my problem. The light works when you use the keyless entry to lock or unlock the doors and it will also work if you use the swithc on the dashboard that controls the backlighting but it won't work when you open the doors. I have put my volt meter on both terminals where the light bulb snaps in and they are both showing 12 volts? Can someone explain how this system works to me? I have also taken the drivers door switch from the wiring harness and I don't have voltage at any of the three wires that go to it.
huntingup1 is offline   Reply With Quote
Old 11-19-2008, 05:01 AM   #2
cburcham73 has a spectacular aura aboutcburcham73 has a spectacular aura about
welcome to the forum. this topic has been covered alot lately here. step 1,get a haynes manual.it will show you how everything is wired. check your door pins. you have 12+ at the light,they use the ground as the switching means.does your dome light have a little switch on the cover?if so,check that also. check the door switches with a meter on ohm's.
cburcham73 is offline   Reply With Quote
Old 11-19-2008, 05:09 AM   #3
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
Make sure that the push button by the light switch is in the on position. It is a cutoff switch for the dome.
Kennyray is offline   Reply With Quote
Old 11-19-2008, 10:36 AM   #4
Got it figured out. It was a combination of things. My stupidity and the drivers side door switch. I had the bypass switch on the dash turned off so no wonder i wasn't getting any fire to the door switch. Thanks for all your help.
Old 11-19-2008, 11:42 AM   #5
Banned
that would do it for ya... glad it was just stupidity and not a pain in the **** like alot of electrical problems on here
need truck wiring diagram silverhairdeere GMC Truck Forum 2 09-05-2008 01:48 AM
Wiring Diagram for 1987 V10 wojeepster Chevy Truck Forum 2 07-31-2008 06:45 PM
need wiring diagram for 76 chevy truck mikeloliver2003 Chevy Truck Forum 2 06-23-2008 06:44 AM
lamp wiring diagram scc457 Chevy Truck Forum 2 03-03-2008 05:41 AM
Wiring diagram? mwalton777 Chevy Truck Forum 9 12-28-2007 06:22 PM
