Old 11-26-2008, 09:29 PM   #1
mamagreg is on a distinguished road
yukon stalls
My 2007 yukon stalls accelerating after stops. And it occassionaly stalls when idling. I've already changed the battery and alternator. Need help on finding the problem or problems. Local dealership could not find anything wrong.
mamagreg is offline   Reply With Quote
Old 11-26-2008, 10:26 PM   #2
FaselZ71's Avatar
Did the stealership scan for or did they try to pull codes? Does it do this everything or just when cold/hot? How could they not find anything wrong if it always does it? I would check sensors and vacuum lines...
Old 11-26-2008, 10:27 PM   #3
FaselZ71's Avatar
Anymore info you can give... What size motor how many miles? Have you ever had the fuel filter changed?
Old 11-27-2008, 04:32 AM   #4
GMC1993Sierra will become famous soon enough
Isn't it still under warranty? I'd try a different dealer.
1993 GMC Sierra (RIP)
186k miles - She'll be missed. But loving the 2009.
GMC1993Sierra is offline   Reply With Quote
Old 11-27-2008, 05:43 AM   #5
call gm customer service if the dealer can't fix it
Old 11-27-2008, 08:38 AM   #6
I believe the dealership pulled for codes. It usually stalls when hot. Its 5.3L with 19,000 miles. Will have the fuel filter changed but I dont think this may be the problem.
Old 11-27-2008, 08:43 AM   #7
checking codes is for autozone. the dealer should be doing a full scan checking the actual sensor readings
Old 11-27-2008, 01:58 PM   #8
All I know is that the dealership told me that they checked "everything" out and found no problem. I dont have much faith in that dealership.
Old 11-28-2008, 10:42 PM   #9
I also noticed that the rpms are lower than 1 when in gear and I have my foot on the brake. Occassionally, the rpms lower a bit and go back to a half to quarter rpm. I dont know if this is normal.
Old 11-29-2008, 06:36 AM   #10
rpms should be lower than a 1000 when put in gear. should be close to the 500-600 mark depending on engine and make model year. in park, they will run 700 to 850. maybe a little more depending out ambient and internal temperature.
Tags
stalls
1990 chevy tk stalls 6chevysforme Chevy Truck Forum 11 10-20-2009 01:09 PM
90 K1500 5.7 Stalls in reverse MScan Chevy Truck Forum 11 10-23-2008 12:45 PM
stalls in reverse josh29j Chevy Truck Forum 5 07-01-2008 03:16 PM
truck stalls in drive mj6971 Chevy Truck Forum 4 06-15-2008 12:34 AM
98 S10 sputters and stalls live2laugh Chevy Truck Forum 3 12-16-2006 06:41 PM
