| Building lowering shackles with money tight thinking about building my own 2-4 lowering shackles , something like this but not the same . eBay Motors: 88-98 CHEVY TRUCK 2WD 2" LOWERING REAR SHACKLES NEW (item 310102868522 end time Dec-02-08 11:51:04 PST) thinking about 1/4 inch steel , but don't know how long they should be . suggestions and ideas welcome . silver hair deere |
| Interesting. Often times I cant build something like this for the same money that I can purchase the same thing. Have you priced out all of the material needed to perform this task? I believe once you purchase enough material to make the shackles, and the bushings, hardware, blah, blah, you light have more than 40 bucks tied up. Either way, in order to get 2 inches of drop, you must re-locate the mounting points 4 inches further apart. Since you are only moving one end of the spring, the amount of drop is divided ny two. So a two inch longer shackle will net one inch of drop. 4 inches longer will only net 2 inches of drop, and so on. Be carefull with hoow long you make them, you do still have limits even though you are dealing with a tension style design. Side loads can fold the shackle, and promote sway. You also have a shackle angle limitation. Too much cmpression can permit the spring to contact the mount if it has enough travel. This is provided that the spring can flatten out that far during suspension cycles. Often aftermarket companies will sell entire hanger kits. This also has an affect on pinion angle, so have some disgression with the amount of shackle length. Normal issues with shock length also apply. |
| welll i was gonna say something along them lines but 75 words things so much better |
| I used some once from the older days meaning the shackles that they would use to raise cars I used some bushing that I had left over from my 1957 F100 Ford leaf springs to cushion where the bolt went though because the leaf spring on your truck already has them but I would recommend buying the kit. |
| Full Member Join Date: Jul 2008 Location: Kentucky
| 96 sierra I installed Belltech 2" drop shackles, lowered rear 1.5" and changed pinion angle enough to cause vibration. Installed 2" drop hangers lowered another 1.5" to level truck and inproved pinion angle less vibration. trouble was the left side was slightly lower than right so I used 1" hole drip on left shackle to correct. stayed with stock shock length but have bottomed out a time'r two so will need drop shocks or extenders. |
| Buroaktree I never had that problem on my trucks that have had them. |
| 2" lowering shackles on 96 Sierra | Buroaktree | GMC Truck Forum | 12 | 10-01-2008 09:59 AM |
| Building up a 360 for my D250 | NxNW | Dodge Truck Forum | 3 | 05-18-2008 04:06 PM |
| lowering a 68 | marko | Chevy Truck Forum | 2 | 05-14-2007 07:56 PM |
| building blocks | bradrhale | General Truck Forum | 2 | 06-10-2006 07:58 AM |
| Building 383 stroker | otrman | Chevy Truck Forum | 3 | 04-13-2006 10:22 PM |
